Old 08-22-2015, 11:57 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Do my numbers look low?
I added 2lbs of boost and 50/50 water meth. My total boost is 10lbs now.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-22-2015, 12:24 PM   #2
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Standard?
Either way I'd say no. I think they look high if it's an auto and really good if it's a manual.
Old 08-22-2015, 01:30 PM   #3
2010_camaro
It's a manual
Old 08-22-2015, 03:02 PM   #4
PQ
Booooosted.
PQ's Avatar
I'd say you are right there. From what I've seen comparable mods. I've seen a few higher and many lower. Considering the difference in any given dyno and conditions I'd be pretty happy with that.
I'll consider a Snow kit once I get my belt slip problem under control.
Old 08-22-2015, 07:04 PM   #5
2010_camaro
I got the gates green belt and it fixed my belt slip.
Old 08-22-2015, 07:30 PM   #6
PQ
Booooosted.
PQ's Avatar
I have a Gates and a JRE Supertensioner. What is a Gates Green belt. Certain belt?
Old 08-23-2015, 04:55 AM   #7
2010_camaro
It's a fleetrunner micro v belt. They are heavy duty belts.
Old 08-23-2015, 06:00 PM   #8
PQ
Booooosted.
PQ's Avatar
Well I believe I'll get one.
Do you have a part number?
And of course...
Old 08-23-2015, 07:16 PM   #9
2010_camaro
Does your car have power steering or power assistance
Old 08-24-2015, 11:35 AM   #10
PQ
Booooosted.
PQ's Avatar
Yes it does.
The stock steering system of course.
Old 08-24-2015, 12:01 PM   #11
2010_camaro
Idk what part number you will need then. My belt is 96 inches.
Old 08-24-2015, 08:55 PM   #12
PQ
Booooosted.
PQ's Avatar
Hmmmmm.............
I can't find them by the length anywhere. I'll find out. Thanks for the idea.
Old 08-26-2015, 05:38 AM   #13
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Those seem like decent numbers....what kinda timing are you running? Whats your AFR?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
