Old 08-22-2015, 12:09 PM   #1
Alan Baban
Alan Baban
Drives: 2011 Chevy Camaro with ZL1 body kit
Unhappy Engine Light is on
Hello dear users and Forum mangers,
I have been facing this issue since I bought my Chevy Camaro which is turning on the engine light. I have searched the internet about the problem and discovered that I should clean the vent solenoid. I took it to a GM dealer and they cleaned it and checked it. The engine light turned off for couple of hours then turned on again. Also, I checked the gas cap whether it is tightened much or not.
Please guys, I know 80% of you have faced this problem. Could you please help me with this problem? because you know that the appearing of the engine light affect the engine's performance.
Thanks a lot
Alan Baban is offline   Reply With Quote
Old 08-22-2015, 12:34 PM   #2
MrChrisLS3
Drives: 2018 1SS M6
Did the GM dealer run a scan? What was the trouble code? Without that, no idea where to even start.
MrChrisLS3 is offline   Reply With Quote
Old 08-22-2015, 01:19 PM   #3
monSSter
monSSter's Avatar
Drives: 2017 SS
agree with mrchris. get a code. if the light is on, run to an auto zone and have them scan it. post up the codes it throwing and I'm sure someone can point you in the right direction
monSSter is offline   Reply With Quote
Old 08-23-2015, 10:52 AM   #4
Alan Baban
Alan Baban
Thanks a lot guys. I will go to a dealer and ask them to rescan and give the the error code.
Old 08-23-2015, 11:07 AM   #5
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
Basing from where you are located, you are in an sandy dusty area, NO?!
If so take a look at the Maf Sensor, replace your air cleaner and do not use any aftermarket CAI that requires an oil spray, and clean out your throttle body inlet.
lawdog is offline   Reply With Quote
