Old 08-23-2015, 03:51 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
AFRs on water meth
So I just happened to see my AFRs in the mid 12s. I'm on 10lbs of boost and 50/50 water meth.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-24-2015, 03:08 PM   #2
MA2010SS
Drives: 2010 Camaro SS
11.3 here 100% meth
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 08-25-2015, 07:34 AM   #3
2010_camaro
I did a pull this morning and I still saw 12.6
Old 08-25-2015, 07:35 AM   #4
2010_camaro
Idk if it's cause the mixture being 50/50 and the water is throwing things off or what.
Old 08-26-2015, 05:28 AM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
11.38 here, I have no idea what you should be on 50/50. Any reason not to run 100 percent?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 08-26-2015, 05:49 AM   #6
1KillerSS
1KillerSS's Avatar
Just a thought here, but water does not burn, so in theory the water should not effect your AFR. If that's the case, then your running pretty lean, but I would ask your tuner.
Build thread
