08-23-2015, 03:41 PM | #1 |
Drives: 2013 Camaro SS Silver Join Date: Feb 2015
Cam install question
I am getting ready to do a cam swap on my L99, probably going with the night fury cam. Question I have is do I have to do the VVT and DOD delete in order to do the cam swap? I have the DOD deleted via my SCT tuner now. I was told that I had to do the DOD delete in order to do the cam. What are the advantages or disadvantages of deleting or not deleting?
Mods: CAI, Flowmaster dual super 10s exhaust, TSP 2" headers no cats, vmax throttle body, catch can, 1.25" BMR lowering springs, GPI SS3 cam, 4K stall triple disk converter, Holley EFI fuel rails
08-23-2015, 03:57 PM | #2 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Yes, to run a Night Fury you will have to delete everything and run a basic LS3 setup. To make more with less, look into a VVT cam and take advantage of what you have.
2010 Camaro SS LS3 - No Modz
08-23-2015, 04:26 PM | #3 |
Gotcha thanks for the info
08-23-2015, 04:56 PM | #4 |
Eh, that'll happen
Look into the GPI SS2, SS3, and SS4 cams depending on your goals. Talk to Rhino79 on here. He has the fastest cam/head only car on the list. VVT is the way to do it!
08-24-2015, 12:04 AM | #5 |
I think he went solid roller now but still lol. VVT cams really have came a long way.
08-24-2015, 02:00 AM | #6 |
They make the night fury with VVT http://www.camaro5.com/forums/showthread.php?t=355226
you need to replace the stock lifters to do a cam and that will eliminate the AFM/dod
08-24-2015, 02:53 AM | #7 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
I always see people on here saying that a VVT cam is the way to go, but then why is there a ls3 conversion kit? Do you make more power with a VVT cam for the L99?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
08-24-2015, 02:58 AM | #8 |
yes you can make more with a VVT cam and better drivability. Aftermarket VVT cams are very new. Not long ago the only cam swaps you could do on a L99 was a LS3 cam so you needed a ls3 conversion kit.
08-24-2015, 03:08 AM | #9 | |
Thanks for explaining! Another question what are some good VVT cams that make alot of power, but are still good for daily driving? I was thinking about getting the Phastek Stage 3 LS3 Camshaft by MTI/Comp Cams with L99 to Ls3 conversion kit and BTR titanium valve springs. Not sure anymore lol.
08-24-2015, 03:18 AM | #10 |
Call Pat G http://www.guerragroup.com/#!camshaft-help/c1mq5 and get a Custom Cam Motion cam.
08-24-2015, 03:23 AM | #11 | |
Oh ok thank you! I will definitely talk to him.
08-24-2015, 08:51 AM | #12 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
Pat G. specd my cam. Excellent results.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
08-24-2015, 10:53 AM | #13 |
Drives: 2014 Camaro SS Join Date: Aug 2015
So would you pick up more hp going non-VVT? It seems to me that ppl going VVT are getting less hp? Is this true?
08-24-2015, 10:59 AM | #14 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I daily drive my GPI VVT SS3.
I have other mods (ported heads, 3.91 gear, 3800 converter), and I just want to share that I trapped 123 and 124 on two different passes last week.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
