Old 08-24-2015, 03:43 PM   #1
kstormoen
Drives: Camaro SS2 L99
Vac Leak?
I need a little help. I have been datalogging my car for Ted to tune at JRE. I have a 2010 l99 with the ls3 conversion kit and a cam from JRE, Whipple S/C with dyntacech LT Headers with off road mid pipe. He is pretty sure I have a vac leak because Bank 1 is leaner. I have tried about everything I have found on this site. Carb clean, Propane, & Soapy water. And never a change in rpms. I'm fairly certain none of the hoses have a small hole. So here is the last thing I tried. I took the intake tube off and put plastic of the opening and clamped it tight. I then removed the middle inlet on the blower and applied 10 PSi of air. I could then hear air coming out of the bolt the holds the linkage on for the vacuum actuator. My questions are..
Should air be able to come out there?
If not how to seal that up?
Thanks
Guys.
keith
kstormoen is offline   Reply With Quote
Old 08-26-2015, 05:30 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
What did Ted say when you asked him? Seems like the place to start if your already working with him.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 08-26-2015, 03:13 PM   #3
kstormoen
Actually found the leak. Bad vacuum actuator. Thanks.
