Old 08-26-2015, 05:30 PM   #1
gsd1862
Drives: 2011 Camero 2LT
2011 RS Gauge issues
This has happened multiple times and randomly...I will be driving down the road and I will start to get a lot of warnings (service park assist, service tire pressure monitor system...ect...) my RPM and Speed gauge will drop down to zero for a couple seconds and then return back to whatever speed and rpm I was at when it happened. but after that all the gauges and information pages on my instrument cluster will be frozen. The HUD also declutters and will only show 0mph. the temp reading on the radio will become -----. From there I can turn my car off and after 15 to 30 sec the instrument panel will turn off. once I turn the car back on it operates normally. no issue with the engine. I already took it to the Dealer and they "could not replicate" since it clears once you turn the car off. possible body control module problem? or electrical problem? please help!
gsd1862 is offline   Reply With Quote
Old 08-26-2015, 05:52 PM   #2
climb-101
Drives: 2010 2ss
sounds like and electrical prob to me. I would check the grounds and make sure there all good
climb-101 is offline   Reply With Quote
Old 08-26-2015, 06:04 PM   #3
gsd1862
I checked the grounds and retightend them
Old 08-26-2015, 08:34 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
#1 cause of these problems is an old battery.
Rock-It Man is offline   Reply With Quote
