Old 08-27-2015, 12:34 PM   #1
Ladykiller
Drives: 2013 Camaro ZL1
What are the logical steps for up to 100-200 more horsepower?
What are the logical steps for up to 100-200 more horsepower on a 2013 ZL1 A6 coupe? I know there are some experts on here on what makes the most sense for modifications for this platform. I also want it to sound better and have headers and high flow cats eventually, but I'm guessing those should be later on in my build and I should worry about getting more air and fuel into my motor first before getting it out.
Let's here it. I'm not really looking for brand name parts or anything like that. I'm only looking for ideas like ... add a pulley first, and a air cleaner second, and so forth ...
Thanks!
Ladykiller is offline   Reply With Quote
Old 08-27-2015, 12:58 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Pulleys, headers, injectors, Intake, boost-a-pump, cam. And tune.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 08-27-2015, 01:51 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
That will do it.
Old 08-27-2015, 01:58 PM   #4
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
If you're looking to do it in stages:
- Cold air intake first
- Then pulley(s), cam, injectors and tune. You might as well do the cam when the balancer is off, and at that point you'll need injectors.
- Headers and another tune last...unless you have the cash to add them with the pulley and cam.
Whos_Drivin is offline   Reply With Quote
Old 08-27-2015, 02:40 PM   #5
TOO.BAD
TOO.BAD's Avatar
Drives: 2013 ZL1 M6 Convertible
It's cheaper to do it all at once rather than in stages. The first thing you should do is a Cold Air Intake. A pretty big bang for the buck.
Mild to Wild Switch, Roto Fab CAI, Big Gulp, Washer Relocation, Ported Throttle Body, Rough Idle Road Race Cam, Supporting Valve Train Upgrade, Dynatech Long Tube Headers Ceramic Coated and High Flow Converters, Injector Dynamics 1025 cc, 22.5%Overdrive Balancer Pulley, Fuel Pump Voltage Booster, Moroso Catch Can.
Jannetty Installed and Tuned.
675 RWHP 630 RWTQ 11.325 1/4 Mile Time @ 124.53 MPH
TOO.BAD is offline   Reply With Quote
