Old 08-28-2015, 09:47 AM   #1
Dobeman2000
Drives: 2015 Camaro SS Convertible
Vibration After New Exhaust
First off, this is my first post on here after looking around for awhile. My wife just purchased a new 2015 Camaro SS Convertible, and I have made my typical mods to it (headers, CAI, and axle back exhaust). A muscle car just isn't right without some muscle and the sound to match it. The problem I am having is after I installed the axle back exhaust (Borla Stingers) the portion of the exhaust right above the flat support bar is vibrating against each other. There is probably only about a 1/4 inch of clearance between the exhaust pipe and the support bar. My question is what can I do to stop the vibration? I have tried repositioning the axle back exhaust but can't seem to gain anymore clearance. Is there some kind of anti-vibration device I can place between the pipe and the support bar? I put a couple of wood shims in between just to verify this was the issue, but that is obviously not a permanent fix. Any ideas? Thanks in advance.
Update: Was able to solve the problem using washers as spacers (many washers), but there is no more vibration.
Dobeman2000 is offline   Reply With Quote
Old 08-28-2015, 11:51 AM   #2
Punisher_ATX
Drives: 2010 SS
Just pull it off. I cant even remember how long ago it was when i took that cross bar off. At least 2 years and no issues. havnt noticed the difference except for a rattle free drive.
Punisher_ATX is offline   Reply With Quote
Old 08-28-2015, 01:35 PM   #3
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
You can add spacers under the "support bar" to give the exhaust a bit more clearance. Its a well known issue here.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 08-28-2015, 02:17 PM   #4
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Exhaust tape. That's what I did cause my 3" stainless works cat back was vibrating on the brace. I also have the provided spacers for the brace but it was barley touching and making a very loud grinding sound. Exhaust tape made it all better
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 08-28-2015, 02:18 PM   #5
bionick
bionick's Avatar
But an axle back doesn't effect that area of the exhaust as its only the rear section where the mufflers are
Old 08-28-2015, 05:08 PM   #6
Higgins@Borla
Drives: Car
Dobeman2000,
Congrats on your new Camaro & exhaust purchases! You mentioned you installed headers and sometimes that will slightly move/clock the mounting positions of downstream exhaust parts. Occasionally convertibles present extra challenges to installation that coupes doesn't.
Hopefully your washer solution helps solve the vibration permanently. But if it doesn't, please call our Borla Sales/Customer Service office at 805-986-8600. We warranty our products for 1,000,000 miles and are always glad to help. Thanks for your business & happy motoring!
Regards,
Chris Higgins at Borla
www.borla.com
Higgins@Borla is offline   Reply With Quote
Old 08-29-2015, 09:35 AM   #7
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
Hey Chris, when I bought my SS in 2010 I had the dealer install their performance axle back system before I even drove it. I've had a lot of people ask me if I have a Borla system. Can you tell us if Borla made the GMPP axle back exhaust dealers were installing?
Thanks,
Jim
Badfinger is offline   Reply With Quote
