Old 08-29-2015, 06:31 PM   #1
HeavyChevySSRS
HeavyChevySSRS's Avatar
Drives: 2010 SSRS
Nitto or Mickey
So I'm still on the fence bout which to buy. The NT05r or the ET street R, or radial street ll.
It's going on a 18" wheel.
I also have looked at the new Hoosier 325/45/18 Dr
I won't be at the track all the time but I also don't daily drive the car. That being said, I want a tire that will stick to the track well and also not be too soft for road use.
I'm ready for the information I am about to be flooded with!
As I lay rubber down the street I pray for traction k can keep, but if I spin and begin to slide please dear god, protect my ride[/I]
10' ls3 2SS/RS, gfx pkg, stainless headers, 3" stainless exhaust, rotofab cai, custom stage 3 cam, 4:11 gears, wall tuned
HeavyChevySSRS is offline   Reply With Quote
Old 08-29-2015, 06:42 PM   #2
TurboLSx
Drives: 2001 Trans-Am
I have ran both on the track and street on several cars. Hp anywhere from 450-850. Both do well on the strip, found the NT05r's liked lower pressures. Both suck in a heavy rain and curvy road.
In the end I ordered another set of MT's yesterday 305/35/18 for mixed use on my turbo car. Mostly street driven, take it to the track about 5-6 times a year.
TurboLSx is offline   Reply With Quote
Old 08-29-2015, 07:05 PM   #3
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Mickey's as well.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 08-29-2015, 07:06 PM   #4
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
MT
Old 08-29-2015, 07:27 PM   #5
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I'm looking into the Hoosier waiting on some replies to see if they fit. They seem like a serious drag "radial". I looks to me like it they wanted to make a slick and did the absolute bare minimum to get it passed as that. I would run MT if you're going to drive it on the street.
Trob85 is offline   Reply With Quote
Old 08-29-2015, 09:23 PM   #6
SuperStock
SuperStock's Avatar
Drives: Imperial Blue 2012 2SS/RS
I have M/T ET Street II's on my third gen firebird street/strip car. I agree that they do suck in the rain but in dry conditions are very nice tires.
Current Mods: CAI Intake, Borla Atak Cat-back, VMAX Ported TB, Elite Engineering Catch Can
SuperStock is offline   Reply With Quote
Old 08-30-2015, 04:15 PM   #7
HeavyChevySSRS
Drives: 2010 SSRS
My car won't touch rain so that isn't really an issue for me.
From previous thread research I think I can concur that the mickeys are softer than the 05r and that results in what turbolsx mentioned, that the Nitto has to be at a lower pressure cause it's harder.
I like the Hoosiers cause they're so meaty and look super intimidating. But yes, they do look like a slick that just makes DOT specs with those few dotted lines
Old 08-30-2015, 06:11 PM   #8
TurboLSx
Look at tire size options from both. I used the Nittos when MT did not offer the size I needed. You will usually find Nittos on the corvettes in the 19"&20" size. Most fourth gen F-body guys run the MT's
Old 08-30-2015, 06:12 PM   #9
TurboLSx
Curious to see how the MT S/S work. Those are due to be out this winter.
Old 09-01-2015, 05:38 PM   #10
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
I have the S/S on 20" and they hook nicely on strip and street
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 09-02-2015, 10:48 AM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
M/Ts work better but they will wear fast if you drive them on the street.
I DD on NT05Rs, been 1.57 on them, but will run a different rim/tire for my big track outings this fall.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-03-2015, 02:23 PM   #12
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
M&H Racemasters.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 09-04-2015, 07:11 AM   #13
TurboLSx
Second set in this size
Old 09-04-2015, 02:53 PM   #14
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Is this the SS tire? It says ET street radial.
MODS:
