Old 08-30-2015, 10:08 AM   #1
ThaCamaroKid
ThaCamaroKid's Avatar
Drives: 2010 Camaro 2SS/RS L99
Exclamation HELP - Won't do above 3,000RPM's & ~30mph!
EDIT: Disconnected battery for 15 minutes, reconnected, problem solved.
Best guess is some sort of ECU limp mode, will leave posted if anybody has this problem in the future
I replaced my starter last night, everything is properly connected, I triple checked all the plugs in that area that I removed and everything is where it should be.
Car fired right up, went to test drive it
Will NOT do more than 3,000 RPM's or above ~30mph, had my foot on the floor and nothing, sounds like I'm doing a 30mph 2-step
Only other things I removed were the passenger side spark plug wires which are back on properly
And I disconnected the battery obviously
No CEL, engine warnings, traction, stabilitrak, no reduced power, nothing like that what so ever. She just won't go!
Car is bolt ons/cam/converter
375RWHP/399RWTQ
ThaCamaroKid is offline   Reply With Quote
