Old 08-30-2015, 09:14 PM   #1
eliminator1974
Drives: 2010 SS 507RWHP.
how oftern to change the oil
Just asking opinions I Have a 2010 ss that I only drive maybe 900-1500 miles a year on it. Just curious on how often do you think I should change it. I do every year when I bring it out of the garage to start driving it in march or april. Any Different Ideas thanks
250cc cylinder heads, G6x3 Comp Cam 111, LSA intake235/647 exhaust 244/612 Fast 102 intake, Nick Williams 102 TB, Stainless Works 2" Long tube headers, Flow master AT cat back. CAI CAI/ADM Scoop, SLP UD pulley, PFTADT .Spring,sways,rear trailing arm. Pedders subframe bushings, energy differential mounts, sphon toe links. BMR 2-point stb, LSR tunnel brace. Hurst short throw shifter, COR Velocity 20" wheels
eliminator1974 is offline   Reply With Quote
Old 08-30-2015, 09:22 PM   #2
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
The official GM statement is once a year or when the sensor tells you to, whichever comes first.
I noticed that the sensor tells me about at 5000 miles.
https://www.facebook.com/photo.php?f...2&l=ea75430571
skuttduck is offline   Reply With Quote
Old 08-30-2015, 09:49 PM   #3
pickwithaustin
pickwithaustin's Avatar
Drives: 2011 Camaro 2SS/RS Convertible and:
If you're not putting on miles, then once a year.
Currently in my Garage:
2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i
pickwithaustin is offline   Reply With Quote
Old 08-31-2015, 07:59 PM   #4
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
I would change it before storage no sense in old oil sitting there all winter.
IMPERIALBLUE2SS is offline   Reply With Quote
Old 09-01-2015, 11:03 PM   #5
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
All good advice from the above comments, but I like to change the oil every 3,000 miles (+-500 miles) or once a year before winter storage.
cajun1le is offline   Reply With Quote
Old 09-02-2015, 07:20 PM   #6
Avenging Orange
Avenging Orange's Avatar
Change mine every spring.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-02-2015, 07:38 PM   #7
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Every 3,000-4,000 miles. Daily driver.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 09-22-2015, 06:28 PM   #8
bobfic
bobfic's Avatar
Drives: 2019 ZL1
Recently picked up 2010 in July, not my first go around, stored all of them in winter months here in Ohio, I always change oil in spring and be for storing it for winter.
bobfic is offline   Reply With Quote
Old 10-01-2015, 02:41 PM   #9
Bulldog3071
Drives: 2010 Camaro 2SS/RS LS3
I only put on about 1000 miles a year and change it every year in October
Bulldog3071 is offline   Reply With Quote
Old 11-23-2015, 11:38 PM   #10
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
Actually you should change it in spring after storage. Oil sitting in the pan won't hurt a thing. During storage temp cycling moisture inside the block and heads runs into the pan and oil. That's why a spring change is best. New oil in the pan in fall becomes contaminated oil by spring.
Kendall421 is offline   Reply With Quote
