Old 08-30-2015, 09:48 PM   #1
gmorcos37
Drives: 2014 Summit White 1LE
Should this be covered under warranty?
The bleeder valves on my calipers were seized and when I tried to bleed the brakes they snapped clean off. I searched online and this seems like a common issue with Brembos (search "brembo broken bleeder"). Already went to a dealer and they said it was my fault since I didn't take it to them for bleeding.
Curious on how I should continue.
gmorcos37 is offline   Reply With Quote
Old 08-30-2015, 09:50 PM   #2
pickwithaustin
pickwithaustin's Avatar
Drives: 2011 Camaro 2SS/RS Convertible and:
Personally, I agree with them.
Currently in my Garage:
2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i
pickwithaustin is offline   Reply With Quote
Old 08-30-2015, 09:56 PM   #3
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Hard to see from the picture but unless there s a material flaw at the bleeder, it's on you for breaking it off. There are ways to unstick siezed parts.
Just like if you took it somewhere for service and the tech broke the bleeder, it would be on them, and it wouldn't be right for them to blame the part to try to not take responsibility.
BigBlock69RS is offline   Reply With Quote
Old 08-30-2015, 10:22 PM   #4
gmorcos37
I understand where you guys are coming from as well, it's just that being such a common problem that makes me think otherwise...
Old 08-31-2015, 08:32 AM   #5
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
You can remove that broken bleeder using left hand twist drill bits. It's likely that the drill bit will cause the broken bleeder to back out during the drilling process. If not, then move along to easy-outs and as a last resort, heat.
I also recommend using kroil penetrating oil during the process. Good luck.
TheHorse13 is offline   Reply With Quote
Old 08-31-2015, 08:53 AM   #6
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Looks like paint on the bleeder screw threads. Was the caliper painted with the bleeder screw installed? Maybe the paint contributes to the problem of it being stuck and needing extra torque to remove.
May need to clear that out as first step?
Ron
ron123 is offline   Reply With Quote
