Old 08-31-2015, 11:37 AM   #1
markallan
markallan's Avatar
Drives: Camaro SS
First time Storing Camaro for the Winter
Hi Guys, I had never stored a car over the winter and this will be my first car to be stored for 6-7 months. I picked up my 2014 Yellow Camaro SS 1LE this January. The car will be stored under an underground parking lot in my apartment. The only thing i know so far is to change the oil before storage. Any advise and input will be appreciated.
Thank you,
Allan
markallan is offline   Reply With Quote
Old 08-31-2015, 11:44 AM   #2
TIREKLR
TIREKLR's Avatar
Drives: 2015 zl1
Also curious to any tips or tricks to help with winter storage. .........
TIREKLR is offline   Reply With Quote
Old 08-31-2015, 12:08 PM   #3
Full Lock
Evasive Maneuvers
Full Lock's Avatar
Drives: SIM '15 1SS 1LE
full tank of gas along with a fuel stabilizer added. jack stands if available to do so aswell to keep weight off one spot of the tires
'15 Camaro 1LE 500whp/444wtq
'04 Avalanche Z71 DD on 33's
'90 K5 Blazer
'13 Camaro 1LE AGM *SOLD*
Full Lock is offline   Reply With Quote
Old 08-31-2015, 12:31 PM   #4
Cleveland1LE
2014 2SS, RS, 1LE Yellow
Drives: 2014 2SS Camaro
I take my tires and rims off and place in my basement. If the tires get too cold, they can crack and will be ruined and are not covered by warranty. The GM bulletin says not to move car when temp is below 20 degrees on the track tires. I know a guy that had his 1LE in his pole barn last year and the tires cracked.
Cleveland1LE is offline   Reply With Quote
Old 08-31-2015, 12:57 PM   #5
Cool1LE
Cool1LE's Avatar
Drives: 2014 Blk 2SS/1LE
oil
any fluids that may need changed (for instance I'm doing my rear diff before storage this year)
Full tank of gas with the stabilizer
battery tender if you have a plug close enough.. if not disconnect the battery all together
I always detail the car (makes spring that much better) then cover it
jack stands are hard on the suspension.... I just put down a tarp (unheated garage helps with the cold) and have 4 carpet squares that add a little (not much mind you) cushion for the wheels... 2 winters and no tire issues after taking it out of storage... more importantly no issues with the suspension from being "dangled" for 6 months
Cool1LE is offline   Reply With Quote
Old 08-31-2015, 01:01 PM   #6
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Do you know how long you plan to own the car?
Are you leaving the stock Goodyear's on it?
How cold does the garage get (is it sealed garage semi sealed open air)?
are you going to be around or are you out town?
Will you drive it at all weather permitting or no way?
Myself mine gets semi stored for 2-4 months depending on the winter. Less now that I realize I will get a new toy car every 5 years anyways so no need treating it like a collector car. I put fuel stabilizer in and a smart trickle charger on it. I start it up every few weeks and pull it out of the garage spin it around few times to rotate the tires around to avoid bad flat spotting and I leave it out running for 15-30 minutes to get it to temperature. I prefer to take it for a quick road trip if the roads are not a winter mess, so that I can get the tranny and rear diff and engine all to temperature for a bit to burn off any condensation.
trashmanssd is offline   Reply With Quote
Old 08-31-2015, 02:42 PM   #7
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
why change the oil before the storage instead of when you get it out next year?
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 08-31-2015, 02:53 PM   #8
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
Gets any water/contaminants out of the fluid so it doesn't sit inside the motor for long periods of time damaging things.
Billy10mm is offline   Reply With Quote
Old 08-31-2015, 03:05 PM   #9
Andoskyy
Drives: 2015 Summit White 2SS/RS 1LE
If you put the jack stands under the suspension, not the body, it won't be dangling. The weight of the car is still on the suspension, just not on the tires.
Would hate to flat spot such expensive tires. It's worth $50 in jack stands to me.
Andoskyy is offline   Reply With Quote
Old 08-31-2015, 04:22 PM   #10
nvydvr
nvydvr's Avatar
Drives: 2015 Red Rock ZL1
You can also go to Home Depot/Lowe's and get a piece of insulation board to park on. A 4 X 8 sheet is around $15.00 and you can quarter it for each tire to get it off the concrete. Just a thought...
Alex
2015 Red Rock ZL1
Panama City Beach, FL
nvydvr is offline   Reply With Quote
Old 08-31-2015, 05:17 PM   #11
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
If it were me, I would put a non alcohol gas in the tank. I've read on the internet, that some of alcohol gas breaks down and adds water.
Old 08-31-2015, 05:58 PM   #12
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I have been storing summer and track cars for 25 years and here is what I do:
Fresh oil
Full take of gas
Battery tender
50psi or air in the tires
Car dollies under tires. Get rounded ones that cup or suport more of the tire
If you want to go the extra step a tarp or drop cloth on the ground
Coal or some other moisture absorbtion for the interior
Moth balls which supposedly keep the mice away
Old 08-31-2015, 07:46 PM   #13
Fireman124
Drives: 45th convertible ss
As others have stated fuel stabilizer, battery tender, oil change, and for the last two years I used Flat Stoppers and they have worked to avoid flat spots on the tires. They are made by the same people who make Race Ramps.
Fireman124 is offline   Reply With Quote
Old 09-01-2015, 01:38 PM   #14
Eldnearb
Chevy for life...
Eldnearb's Avatar
Drives: 2011 RS/2SS Black
Send a message via MSN to Eldnearb Send a message via Yahoo to Eldnearb
I have been wintering her for 4 years and my list is like most others.
Oil change
Full tank with Stabilizer
fill the tires
park it on wood to keep it off the concrete
Battery tender
padded Winter cover
park her in the garage and don't start her up until the spring.
No issues, original tires (only have 22,000KM on her).
Don't forget to stare at her all winter, occasionally I sneak out to the garage to have a seat and prepare for the thaw.
2011 2SS Black w/Cyber Grey Stripe
Chevy for life...
1987 Chevy Celebrity, 1992 Chevy Cavalier, 1995 Chevy Camaro, 2001 Chevy Blazer, 2002 Chevy Silverado, 2011 Chevy Camaro
Eldnearb is offline   Reply With Quote
