Old 08-31-2015, 09:56 PM   #1
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
Will these fit?
I want to buy a set of Factory Reproduction drag wheels (18x12) and wondering if these tires would fit. This is a pretty good price if they work. Thanks
http://www.jegs.com/i/Hoosier/522/17...rentProductId=
Rico is offline   Reply With Quote
Old 09-01-2015, 07:02 AM   #2
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Those are only 26" in diameter. Check out the wheels/tire sticky on the dragstrip section. I think they recommend that you not go lower that 27 inches. There's a member who fit the Hoosier DR2 (325/45/18) on some 18x9.5 wheels so I think those would fit perfectly on the FR 18x11 wheels that you plan to buy. BTW, the DR2 are only like $20 more per tire than the ones on the link you posted. http://www.tirerack.com/tires/tires....dewall=Painted White Letters&partnum=245R8DDR2&tab=Sizes
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 09-01-2015, 12:29 PM   #3
Rico
Rico's Avatar
Drives: Black SS/RS
Thanks for the suggestion, I'll check them out. I'm just surprised at how much cheaper these are then for MT drag radials.
Old 09-01-2015, 01:51 PM   #4
760bowtie
760bowtie's Avatar
Yea I've seen good reviews on them and would go with those but they don't fit because of my height in the rear.
