Old 09-02-2015, 02:41 PM   #1
cammotion perf
cammotion perf's Avatar
Drives: cam tech
Thumbs up Cam Timer Valve Event Calculator by Cam Motion
Cam Motion is happy to provide our handy Cam Motion Cam Timer free for download to tech savvy engine builders, racers & enthusiasts.
This quick and handy camshaft valve event calculator is quick to pull up and easy to use. You can change any of the fields (except for overlap) and all of the other fields will automatically update after clicking the update button. You can open multiple instances of this application at once, so comparing a few different profiles is easy.
Here is a preview image of the program:
This windows application download is contained in a .zip file. Merely download the .zip file from the page linked to below, unzip the file and it is ready to go. Enjoy!
You can download the Cam Motion Cam Timer here:
http://www.cammotion.com/cam-timer.php
Be sure to share this free Cam Timer with your fellow performance industry professionals and technical minded racers and enthusiasts.
If you have any questions, you can ask them here.
cammotion perf is offline   Reply With Quote
Old 09-22-2015, 05:49 PM   #2
cammotion perf
Drives: cam tech
Here is another handy one for you all. It is a static & dynamic compression calculator. Like the Cam Timer, it is quick and easy to use, allows you to update any field (except for the calculated compression ratios) and you can have multiple instances open at once, which can be very handy when comparing different compression or camshaft scenarios. Check it out!
http://www.cammotion.com/engine-calculators.php
