Old 09-02-2015, 02:55 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Ordering Kirkey economy drag seat..need install advice
Gonna order Kirkey seats. Should I order the bracket too or just bolt the seat where I want it? Any fabrication needed?
AIRBAG fuse pull and call it a day?
Im thinking of ordering a Summit plastic seat for the pasenger side...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 09-02-2015, 02:57 PM   #2
JusticePete
Drives: Camaro Justice
Are you using a harness?
Caged or harness bar?
Old 09-02-2015, 03:09 PM   #3
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Nothing...just weighr reduction for a 11s pass (hoping)
13' 1LE
Old 09-02-2015, 04:04 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I had both in 4th gens. I liked the plastic Jegs seat more to drive around in.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-02-2015, 04:06 PM   #5
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
What about installation?
13' 1LE
Old 09-02-2015, 06:01 PM   #6
Pro Stock John
Writer
Been a while but we had the Kirkeys just about mounted to the floor:
Jegs seat I think it came with a sliding metal base, we used it:
PROJECT HEAVY CHEVY
Old 09-02-2015, 08:13 PM   #7
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
There are a couple companies that make seat bases that bolt right into the stock locations.
Google it.
Trackman is offline   Reply With Quote
Old 09-02-2015, 08:26 PM   #8
JusticePete
The three point stock seat belt is designed to work with together with all the factory air bags. When you remove and OE safety device it should be replaced with an aftermarket safety device. Unless I am mistaken, the back of the Kirkey is designed to be attached to a roll bar.
From the Kirkey website for the Series 16 seat.
FAILURE TO COMPLY WITH THESE INSTRUCTIONS MAY CAUSE
SERIOUS INJURY OR DEATH.
MOUNTING INSTRUCTIONS
This seat is to be mounted using the following instructions. For the bottom
of the seat, we recommend that you use no less than four (4) 5/16” (8mm)
bolts directly through the bottom of seat to the frame or roll cage.
(spread the bolts out as far as possible to distribute the load). For the back
of the seat, we recommend no less than two (2) 5/16" (8mm) bolts
through the back of the seat (below the shoulder belt openings)
to the roll cage.
NEVER mount to sheet metal.
We need a better plan to get into the 11s.
Old 09-02-2015, 09:47 PM   #9
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
The economy drag seat doesnt need to be attached to a roll bar, I think. thank you for the advice!
I'm at 12.76@113mph with a horrible 2.2 0-60ft. Race star on the way in 17'' front and rear with drag radials. This might do the trick with removed passenger seat. I could add ported intake and TB to complete this.
13' 1LE
Old 09-02-2015, 09:48 PM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Thanks a lot for the pic!! Might go with jegs..but shipping is way less with Summit to Canada...
Google it.
I've seen some but theyre like 200 bucks...
13' 1LE
Old 09-02-2015, 10:00 PM   #11
JusticePete
I have installed several Kirkey containment seats, but not any of the Series 16 Drag Seats. I did reference the Kirkey installation instructions for the Series 16.
https://www.kirkeyracing.com/images/...on%20Guide.pdf
For the back of the seat, we recommend no less than two (2) 5/16" (8mm) bolts through the back of the seat (below the shoulder belt openings) to the roll cage.
Old 09-02-2015, 10:45 PM   #12
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Ok so no Kirkey then...
13' 1LE
Old 09-03-2015, 12:36 AM   #13
62nalide
62nalide's Avatar
Drives: 2013 SS
I ordered the Copo seats
I'll post picks when they go in
62nalide is offline   Reply With Quote
Old 09-03-2015, 01:48 AM   #14
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
^^wow..what an idea!! Youre telling me that when I just ordered summit seat LOL, 2 mins ago!
13' 1LE
