Old 09-03-2015, 09:39 AM   #1
NYStockboy
Drives: 2013 Corvette Grand Sport
All season tires for the ZL1
Spoke with a Tire Rack rep regarding a good all season tire for the ZL1 in stock sizes.
He said the only tire available in stock sizes is the Goodrich G Force Comp 2 A/S.
Is there any feedback on this tire or is it new to the market?
Thanks.
NYStockboy is offline   Reply With Quote
Old 09-03-2015, 10:40 AM   #2
CurtiSSWatson
CurtiSSWatson's Avatar
Drives: Black SS
I drive an SS with bolt ons, in North Dakota. All Season tires, really do not do much. For two winters, I used my Pirelli Ice Scorpions (same size as factory), and for the third winter, I stayed on my factory street tires with no problem. North Dakota is always icy. Hopefully this information helps you.
CurtiSSWatson is offline   Reply With Quote
Old 09-03-2015, 12:00 PM   #3
AIminiS10
AIminiS10's Avatar
Drives: 2012 Camaro ZL1 - #1564
I have been curious about these tires also since they are relatively new to the market. I am curious if they can handle the power to the ground.
2012 Chevy Camaro ZL1 #1564
1969 Chevy Chevelle
2000 Honda CBR 929rr
2013 Focus ST (daily)
AIminiS10 is offline   Reply With Quote
Old 09-03-2015, 06:25 PM   #4
2K13_ZL1_BLove
Drives: 2013 Summit White ZL1
I run Contintental DWS ExtremeContact All Season Performace tires. They hook up well in the cold and rain, and are slightly sticky on hot days still. I like them. 315 rear 275 up front
2K13_ZL1_BLove is offline   Reply With Quote
Old 09-03-2015, 10:14 PM   #5
TobysZL1
TobysZL1's Avatar
Drives: ZL1 Gone but not Forgotten!
+1
I run the same tire only I have the stock 285 up front, 315 out back. These tires hook great, way better then the stockers. Are great in the rain and are ten times more quiet then the GY .
They have to be the best all around tire, I have no question .
Sent from my SM-N910V using Tapatalk
TobysZL1 is offline   Reply With Quote
Old 09-04-2015, 10:55 AM   #6
TOO.BAD
TOO.BAD's Avatar
Drives: 2013 ZL1 M6 Convertible
I have the same set up and think these Continentals are great.
Mild to Wild Switch, Roto Fab CAI, Big Gulp, Washer Relocation, Ported Throttle Body, Rough Idle Road Race Cam, Supporting Valve Train Upgrade, Dynatech Long Tube Headers Ceramic Coated and High Flow Converters, Injector Dynamics 1025 cc, 22.5%Overdrive Balancer Pulley, Fuel Pump Voltage Booster, Moroso Catch Can.
Jannetty Installed and Tuned.
675 RWHP 630 RWTQ 11.325 1/4 Mile Time @ 124.53 MPH
TOO.BAD is offline   Reply With Quote
Old 09-04-2015, 11:00 AM   #7
CTSVBiggie
CTSVBiggie's Avatar
Drives: 2013 1LE
Id suggest the Contis from previous experience.
But my 1le(same wheels as ZL1) came pre swapped with all season performance Dunlops. They are OK grippy in the summer. But are supposed to(I tend not to drive when it snows) be good in the winter.
>>>>>>>>>>>MUST READ DISCLAIMER<<<<<<<<<<<<
2013 Crystal Red Tint Coat - 2SS RS 1LE
CTSVBiggie is offline   Reply With Quote
Old 09-09-2015, 01:39 PM   #8
boondocksaint
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla
I have the same setup and, with my experience in snow in Detroit driving a heavy RWD car, the DWS can handle nominal amounts of snow. Ice, I don't know. But snow up to four-to-five inches, I handled with no problem. And they're quiet and semi-grippy for an all-season.
If you have big-time winter weather, get some narrower wheels and dedicated snows.
boondocksaint is offline   Reply With Quote
Old 09-09-2015, 02:15 PM   #9
flatrockguy
flatrockguy's Avatar
Drives: 2015 Black ZL1 m6, gone 2012 CTS-V
I'm going to give the BF Goodrich G Force Comp 2 A/S a try. I ran Blizzaks on my CTS-V and they worked great but were very costly so I figured I would give these a try for the colder months. If they suck too bad in snow I'll just stay home from work.
flatrockguy is offline   Reply With Quote
Old 09-10-2015, 12:36 AM   #10
geforce
geforce's Avatar
Drives: 2010 SS1 LS3
Size:  73.6 KBI have had these tires on the front of my ZL1 since August, Goodrich G Force Comp 2 , I like the look and feel sound seems less noisy to me also, the back tires our still stock,
2013 zl1 ashen grey,
2010 SS LS3 imperial blue metallic, traded
2010 camaro ls burnt orange, traded
geforce is offline   Reply With Quote
Old 09-13-2015, 10:01 PM   #11
Emvici
Drives: 2014 ZL1 White Convertible
Originally Posted by TobysZL1 View Post
+1
+1 again, I would just say make sure you don't run more than 34 psi in the tires or the tires will bounce you off the road on fast accelerations due to the twin steel belts. great tire.
Emvici is offline   Reply With Quote
Old 09-13-2015, 10:15 PM   #12
ZiG
ZiG's Avatar
Drives: 2011 2SS/RS LS3
I run dedicated winters: Goodyear Ultra Grip Ice in 215-60-16. They work great.
2011 2SS/RS LS3
Rotofab CAI/scoop/washer - FE4 conversion - Pfadt ZL swaybars - BMR endlinks - Hurst short shifter - RKSport spoiler
ZiG is offline   Reply With Quote
Old 09-22-2015, 12:45 PM   #13
flatrockguy
Do the 315's fit without problems on the rear?
Old 09-22-2015, 12:47 PM   #14
TobysZL1
TobysZL1's Avatar
Yes they fit 100% without issue.
