Old 09-03-2015, 01:57 PM   #1
kencam
kencam's Avatar
Drives: 2010 2SS/RS M6 Maggie Rally Yellow
Long tubes and STFT readings
I put on some long tube headers with hi flo cats a few months ago.
I took a OBDII reading after noticing a CEL and here are the results:
Bank 1 Sensor 1 : O2 - 0.87v, STFT 0.7%
Bank 1 Sensor 2 : O2 - 0.87v, STFT 99%
Bank 2 Sensor 1 : O2 - 0.935v, STFT 0.7%
Bank 2 Sensor 2 : O2 - 0.675v, STFT 99%
I'm not sure what's going on here, but I don't think a 99% value on a sensor is normal.
Would a non fouler on the rear sensors help?
kencam is offline   Reply With Quote
Old 09-03-2015, 05:36 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Are you tuned?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 09-03-2015, 06:51 PM   #3
Tenring
Tenring's Avatar
Drives: 2015 SS/RS M6 Commemorative
Dizzys question?
It took a couple months to get the CEL?
Tenring is offline   Reply With Quote
Old 09-04-2015, 01:41 AM   #4
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
For what it's worth, disregard your 2nd sensor readings they mean nada with long tubes. If you were in fact tuned your tuner would have tuned them out completely anyway. Your sensor one readings look ok.
You may want to look into a wideband to see what your A/F is looking like at WOT though so you know your engine is running ok and not going lean. Just my .02
JD_Alaska is offline   Reply With Quote
Old 09-04-2015, 01:46 AM   #5
JD_Alaska
JD_Alaska's Avatar
Are your LTFT sensor 1 ( both banks) matching or close to your STFT for sensor 1 (both banks)?
