Old 09-05-2015, 05:54 AM   #1
NOLA_1LE
NOLA_1LE's Avatar
Drives: 2013 Camaro 1LE
F1-R Install
I thought I would start a thread for my new build that I started. A few months ago is started collecting parts and now it is all about to come together. If all goes well it should be on the street the first week of November!
The goal is to make a safe 850+ rwhp hopefully I can get there.
2013 2SS/RS 1LE Inferno Orange
Under the Hood:
TSP 376ci forged bottom end
PRC 260cc heads with the 1/2" stud upgrade
BTR cam
F1-R cog w/ race intercooler
ID 1000’s
Fast Intake and fuel rails both black
Fore level 2 system w/ TI262 pumps, FC3 controller, Teflon -8 feed/return, reusable stainless filter w/ billet mounting bracket, and honeywell pressure switch
Alky control dual nozzle kit w/ AIS trunk tank
Borla LT's and CAT back ATAK
Suspension all Pfadt:
Lowering springs
Rear trailing arms and tie rods
Rear drag sway bar
Rear upper and lower control arm bushings
Solid Sub frame bushings
Front spherical trailing arm bushings
Front lower control arm bushings
Interior/Exterior:
AEM boost and wide band gauges w/ A pillar pod
Barton short throw Shifter
VIS CF terminator hood
ZL1 CF spoiler
2013 1LE Inferno Orange 848hp 836tq
TSP Forged 376ci motor w/ 1/2" Head Studs and PRC 260cc heads, F1-R Procharger Cog Drive w/ Race Intercooler, Fore Fuel System, ID1000's, Alky Meth Kit, Mantic 9000, Borla LT and CAT back ATAK
Pfadt: Lowering Springs, Rear Trailing Arms and Tie Rods, Rear Drag Sway Bar, Rear Upper and Lower Control Arm Bushings, Solid Sub Frame Bushings, Front Spherical Trailing Arm Bushings, Front Lower Control Arm Bushings
Barton Short Throw Shifter, AEM Boost and Wideband Gauges w/ A Pillar Pod, VIS CF Terminator Hood, and ZL1 CF spoiler
NOLA_1LE is offline   Reply With Quote
Old 09-05-2015, 07:51 AM   #2
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
What's the goal of the car? Drag race? Street machine? Highway pulls ? Or just drive it around town?
Trob85 is offline   Reply With Quote
Old 09-05-2015, 09:32 AM   #3
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
850 goal
Your goal should be fairly easy to obtain with that combo. I am making slightly over a 1000 with E85 and F1R and prior to that I made 880 with F1A.
You didnt mention it but you are going to need better axles and driveshaft. I would do DSS components there.
Use the 1300HP procharger race intercooler and RED race blowoff valve. I assume you are running an Auto? I would also use LS9 head gaskets as they will hold boost better. Somewhere around 18 pounds of boost should get you there.
On a side note if you ever wanted to run an F1X procharger later that would work with your combo because you have electric power steering. On NON-electric power steering cars, you have to modify the power steering fluid tank to make it smaller so it can clear the larger volute on the F1X.
The FAST intake is not really beneficial except on larger CI combos. Be wary of running non-stock throttle bodies as they can flutter at high boost levels and make the car go into limp mode. Since you are running 4 bolt heads, 25PSI is about the MAX you can run with those before potentially lifting the heads. You wont have to worry about that now however. 6 bolt heads will allow you another 8-10PSI margin if everything else is right. LSX or ERL would be my block of choice in extreme HP applications (1200RWHP up).
__________________________________________
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 09-05-2015, 09:52 AM   #4
Trob85
Svt lol
Trob85's Avatar
Also not mentioned the fast intake has a tendency to separate under boost. Not saying it will, just wanted you to know that it has happened so consider the possibility you might need to switch to a mid ram Holley or back to stock.
Old 09-05-2015, 09:53 AM   #5
TheBandit18
TheBandit18's Avatar
Drives: 2011 Camaro 2ss M6
What fuel you running? I was told you shouldn't run e85 with the t1262 fuel pumps.
TheBandit18 is offline   Reply With Quote
Old 09-05-2015, 10:19 PM   #6
NOLA_1LE
NOLA_1LE's Avatar
Thanks for the input, I have been thinking about the driveshaft and axels but the intent of the car is mainly just to be an insane street machine. My thoughts were as long as I don't run slicks or drag radials I shouldn't tear the axels up too bad.
I actually do have the rave intercooler so all good there, I only ended up with the fast intake because I got a great deal on the intake and fuel rail combo.
I did upgrade to the 1/2" head studs just to help handle the boost, I want this motor to last so I only plan to crank up the boost enough to get to my 850 goal.
Old 09-05-2015, 10:21 PM   #7
NOLA_1LE
NOLA_1LE's Avatar
The current plan is to run 93 with meth
Old 09-05-2015, 10:22 PM   #8
NOLA_1LE
NOLA_1LE's Avatar
Street machine/Sunday cruiser
Old 09-05-2015, 10:49 PM   #9
sr71bb
sr71bb's Avatar
Axles
Well I will tell ya that at the 1000 rwhp I did run stock axles and driveshaft but I mostly roll race. After Runway Rivalry II , I replaced the stock driveshaft and upon inspection I found I pretty much had trashed it but the car was dead hooking on 17 in 325 M&H Racemaster tires.
I DID break the driver side axle the very first time I went from a dig but this also was AFTER the Runway Rivalry II race. At that time I replaced the axles with GFORCE axles but I broke the iNSIDE CV joint on the passenger side GFORCE axle. We then replaced axles with DSS axles. No issues so far.
If I did much drag racing form a dig I would have to replace the stock SS rear pumpkin but it seems to be holding pretty well for roll racing
Retired Cars BELOW:
Old 09-05-2015, 11:10 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You should be able to do it pretty easily. I made 825whp with a Ysi and then made 1026whp with the same Ysi after pulleying it down, adding meth, and a custom cam.
Old 09-07-2015, 11:22 PM   #11
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
I would do agp intercooler it is made for Procharger we are trying a 12 rib for the street Name:  image.jpg
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 10-10-2015, 09:15 PM   #12
NOLA_1LE
NOLA_1LE's Avatar
Starting Install
Well the motor arrived and work has started on the install!
Old 10-10-2015, 09:40 PM   #13
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I just realized you are in KC too! I also see a Ford racing sign on the garage wall.
Old 10-10-2015, 10:04 PM   #14
pdiddy
Drives: 2011 2SS
There is a few Kc guys now with fifth gens and built motors my motor should be here soon similar build but smaller blower I am using ecs 1500 for now going to spin it as fast as I can with out hurting it
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
