Old 09-05-2015, 10:22 AM   #1
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
Car lowered with Pfadt springs but after alignment rear sits high again
2014 Camaro SS 1LE.
Installed some PFADT springs about a week ago. Car looked great, I was very happy with the drop.
After waiting about about a week for the car to settle, I took it to get aligned and bushings timed.
Unfortunately, it seems that the car was serviced by an inexperienced tech. The tech had a lot of trouble timing the bushings, I dont think it was done correctly. The car was barely set to the specs that I provided them with, and the more important issue is that the rear now sits higher than how it went in (a little over half an inch).
Im not sure what they did that could have caused the car to end up with this bad rake.
Any ideas on how to get the car's rear back down, leveled with the front?
Here is a photo of the alignment data.
ZYBORG is offline   Reply With Quote
Old 09-05-2015, 10:50 AM   #2
kfiruta
Kyle 1LE
kfiruta's Avatar
Drives: 2015 Camaro 1LE black
Interested on any info you aquire as just ordered the same springs for my 15' 1LE
1CF
kfiruta is offline   Reply With Quote
Old 09-05-2015, 01:57 PM   #3
JusticePete
Drives: Camaro Justice
Get your Camaro on a level surface and measure the ride heights, preferably in mm. Measure from the bottom of the wheel rim lip, up through the wheel center to the painted edge of the fender at all four wheels. That a profile picture of the car and post the results here please.
Old 09-05-2015, 03:59 PM   #4
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
Got the car on as leveled of a surface as I could, here are the measurements:
LF: 655mm RF: 650mm
LR: 670mm RR: 667.5mm
*While measuring, I noticed the LF tire sticks out more than the RF tire, by about 10mm.
Here is a picture with the Pdaft springs, AFTER the alignment...
And here is a picture with the Pfadt springs, BEFORE the alignment...
Old 09-05-2015, 09:44 PM   #5
JusticePete
Stock rear ride height averages 630mm so you are 3/4" lower. My guess is by timing g the bushings and aligning you will be close to the correct drop. I'll post detailed instructions shortly.
Old 09-05-2015, 10:12 PM   #6
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
The thing is that the car already has been "aligned and bushes timed". I put it in quotations because I am not sure hiw good of a job the tech did.
Also, my main concern is that rear went up in height a little over half an inch after the "alignment and bushes timing".
Old 09-05-2015, 10:52 PM   #7
JusticePete
Sorry. My last reply was from my phone. The alignment specs are decent. The rear camber going from -1.1 to -.30 will raise the ride height about about 10mm. Front camber from is about the same amount of change -0/.3 to -1. in front the ride height will change less, maybe 5mm. Together they amount to a solid 1/2".
You could go back to the alignment shop with these instructions printed and ask them to go through the process again.
The Book of 5th Gen Camaro is getting an update.
http://www.jpssonline.com/the-book-f...-2010-camaro-2
5th Gen Camaro Alignment, Bushing Timing and Torque Specifications
DO NOT USE OFFSET CAMBER BOLTS ON THE 2010 - 2015 5TH GEN CAMARO. The OE clevis bolts are much stronger and the offset bolts are NOT needed with an excellent system installed at the factory.
This is the correct way to adjust front camber on the 5th Gen. One the alignment machine with the clevis bolts loose turning the camber screw tighter (Righty Tighty, Lefty Loosey) will push the knuckle away from the strut. Loosening the camber screw allows the knuckle to fall in toward the strut. It is a 10mm 1.5 pitch thread.
It isn't pretty, but it was laying around the shop so we used it. A bolt this large is ONLY for use on the alignment rack and should be removed before driving.
This is a JPSS style Camber Screw. We recommend using LocTite blue to prevent it from backing out. Note that in this picture you can see the upper hole in the factory strut is elongated for camber adjustment.
On the alignment rack, any 10mm 1.5 pitch bolt will do. The correct way is to use a JPSS style Camber Screw with blue LocTite. Your alignment shop may have a T.O.M.C.A.T. Air-Assisted Multiple Camber Adjustment Tool air bag.
It fits between the wheel and the strut and works in the same way as the camber screw. Inflate (Righty Tighty) the bag to push the knuckle away from the strut or deflate (lefty Loosy) the bag to allow the knuckle to fall into the strut. If they don't, they have a guy that can push or pull on the wheel while they tighten it. Never, ever use offset camber bolts on a Camaro. EVER!
JPSS foundation as a company is more than just a range of bits, we are suspension specialists committed to delivering a JPSS Driving Experience. A lowered vehicle should have a full range of alignment adjustments. The Camaro delivers from Chevrolet with a fixed Castor position. The radius arm bolts into round holes with no available adjustment. Front Camber is adjustable from the factory. There is a threaded hole for front Camber Adjustment Bolt / Screw, but no bolt is installed and no part number is listed by Chevrolet. The rear OEM eccentric adjusters for Toe and Camber provide approximately one degree adjustment range. For an alignment specialist, this is unacceptable. You want to get your Camaro perfectly setup. This is what JPSS is all about. Our solution is a set of Black Magic JPSS Alignment Bolts. While GM made the hole round for the front Castor Adjustment or lack thereof, they did weld in brackets for an eccentric to work against. Your local JPSS Dealer can create a slot to provide Caster adjustment with JPSS Camaro Alignment Bolts. The kit provides the front Camber screws that GM didn't.
For the 5th Camaro, GM decided to produce the front sub-frame with only a round hole, but they kept the 'fences' for caster adjustment with eccentric bolts just like the Pontiac G8 and Holden Commodore. The slots to allow adjustment were lost in translation. For a performance driver, a vehicle without full alignment adjustment capability feels like driving with one hand tied behind your back. JPSS made the decision to make the Camaro front suspension fully adjustable.
Stock Radius Bush Mounting area with a round hole and adjustment 'fences'.
In Step #1 the technician may choose to drill two holes, one on either side of the factory hole before grinding a slot shape. Other techs will just grind the slot.
The eccentric that will be used does not reach all the way to the bracket sides so a bit of excess metal is not an issue. The technician can check the clearance with a JPSS Castor Eccentric Bolt as they grind to make sure the fit is JPSS dead nuts on.
We use black chromate plating on our Camber Bolts. We used a gold tone bolt in this image to make it easier to see.
When assembled the plated eccentric allows the alignment technician to increase or decrease Castor. A well aligned Camaro with good tires will not require ANY BIAS in the alignment. Should your Camaro be tweaked and develop a pull the same JPSS Caster Eccentric Bolts can be used to create a bias to correct the pull. We strongly recommend that before you alter your alignment due to a pull that you have a qualified technician, because the machine is only as good as the tech, check your tires on a road force balance machine to make certain the pull is not induced by a tire. When the tires have been confirmed good, we can make adjustments on the alignment rack.
For those that track the 5th Gen Camaro we have created Black Magic Caster Locks. Using a Caster Lock there is no possibility drift under the most demanding driving conditions. Installation of the Caster Locks is very similar. The slot is ground forward toward the radiator.
There are four Caster Lock plates that are installed on both sides of each radius arm bushing. We used a raw bare aluminum plate for this illustration.
Increasing caster improves straight line stability and the return of the wheels to the on center position. Adding caster to the 5th Gen is highly desirable.
Alignments are JPSS core business. We offer the JPSS Black Magic Caster, Rear Camber and Front Camber Screws. When installing the JPSS Front Camber Screw it is essential that you use LocTite Blue. The Camber screw will never bear a load while driving, but we want to make certain they never vibrate out.
JPSS Rear Eccentrics are virtually bullet proof with 1.8 degrees or double the factory adjustment. With the Camaro alignment Kit installed your Camaro can be setup for the drag strip, road course, auto cross or every day flawless driving. Even better, JPSS alignment eccentric bolts carry a unique warranty feature. Should a JPSS eccentric ever fail while you own the vehicle we will replace it. You get a superior alignment, improved driving experience and a life time warranty with JPSS Camaro Alignment Bolts.
To get the aggressive alignments we prefer JPSS Black Magic Camber and Caster Bolts and Camber Screws are essential. They double the adjustment range . We achieve this result my moving the eccentric to the outer edge of the bolt. The eccentrics are cut on a water jet, assembled in a jig and welded. This is a time consuming process. To finish the bolts we have coated in black chromate.
Taking the performance of your 5th Gen and alignment to the next level requires the use of JPSS Knockout Camber Plates. With the stock front struts or coilovers you can achieve -2.2 Degrees of front camber. Relieving the upper slot in the strut to allows it to fall in a bit more will get you to -2.5. When running high negative camber it is Mission Critical to check spacing between the inner tire sidewall and the strut or coilover. We use a standard #2 lead pencil as a gauge. If the pencil passes between the tire and the strut or coilover you are good to go. With JPSS Knockout Plates we suggest you run them full in, maxed out for negative camber. Positioning the strut top well in toward the engine improves SAI. Your 5th Gen will drive better. Final adjust the negative camber at the knuckle using the camber adjustment screw.
JPSS are a Knock Out by design, construction and function. The bearing plates are made of stainless steel. The hardware is stainless steel. Our bearings are the finest made in America available. Of course none of this matters if they are not the most functional in the industry. It starts with a hard mount system. Some 5th Gen Camaro owners will cringe at the thought of drilling six mounting holes in their strut towers, but most will agree it makes sense when they understand why. We don't want it to move. Period. Anything that clamps in place can move on impact with a pothole or gator-back. Bolted in place, the only way to move a JPSS camber plate is to move the entire strut tower.
JPSS Knock Out Camber Plates deliver 2 full degrees of adjustment. Not 1 degree. Not 1 degree split between caster and camber. 2 full degrees. If you want to add caster, and we highly recommend you do, use our Caster Locks or of Caster Bolts. Camber plates on a 5th Gen Camaro are reserved for Camber and Steering Angle Inclination (SAI).
Steering axis inclination acts, with caster, to provide a self-centering of the front wheels. When the wheels are in the straight-ahead position, the ends of the stub axles are almost horizontal. When the wheels turn to either side, the effect of steering axis inclination is to make the ends of the stub axle tend to move downward, but this is prevented by the wheel. The stub axle carrier then must move up, which raises the front of the vehicle. When the steering wheel is released, the mass of the vehicle forces the stub carrier back down, which pushes the wheels back to a central position.
The SAI angle is created and measured in degrees. It runs from the lower ball joint through the upper ball joint, or on most front wheel vehicles, through the center of the strut mount. The illustration uses ball joints to represent the angle. This measurement of degrees includes the measurement from lower ball joint to the upper ball joint or the upper strut mount and true vertical (the tire actually sitting straight up and down). The SAI angle doesn't include the camber angle. This is because Steering Axis Inclination is a non-adjustable angle.
We recommend using the JPSS Knockout Camber Plates to increase SAI and adjust the majority of camber at the knuckle. Combine this with JPSS Caster Locks to achieve optimal front end geometry and handling.
Bushing Timing
Step 1. Lift the car on a two post lift and raise it.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Lower the car and drive it around the parking lot SLOWLY and on to the alignment lift.
Step 4.
With the weight of the car on the wheels tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Alignment
On the alignment rack the technician must be aware that the rear lower control arm camber adjustment works against the toe link toe adjustment. The toe eccentrics should be set to a neutral position, the eccentric not touching the 'fences' when thee initial camber adjustment is made. Then the technician will work the two for the optimal split of camber and toe values.
Front and Rear Bolt Torque Values
NOTE: Torque specifications that read XX torque value and XX degrees are typically Torque to Yield (TTY) and require replacement of the bolt, nut or both. If replacement parts are not available from GM, the minimum acceptable torque will be those values stated along with a liberal application of a thread locker i.e. LocTite
Old 09-06-2015, 10:58 AM   #8
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Pete how long are the 10mm bolts supposed to be?
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 09-06-2015, 11:17 AM   #9
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
This is the best info on alignment I've seen yet! Thanks Pete.
its a syn is offline   Reply With Quote
Old 09-06-2015, 04:36 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
45-50mm will do it (1and3/4"-2inches), but remember to take'em out after it is aligned. I thought a little tension and blue lock tight would keep mine in place and I lost one.
Old 09-06-2015, 05:30 PM   #11
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
Thanks
Great timing! copied and appreciated!
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 09-06-2015, 06:55 PM   #12
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
Pete,
Thank you very much for your insight!
I think what you mentioned about the differences in camber is the cause of my lifted rear. I think I will hve the car re-aligned by another shop and have the alinment set to the Pedders Agressive Street: -1.25 camber in the front and -1.00 camber in the rear.
Now, Id like to figure out what could be causing the LF wheel/tire to stick out more than the RF wheel/tire?
Old 09-07-2015, 01:36 AM   #13
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
Pete,
Someone pointed out to me that the 630mm number for a stock 1LE might be a typo. Since I am lower than stock and I am sitting at around 670mm for the rear, maybe you meant the stock measurement for the rear of the 1LE to be in the 690mm range?
Old 09-07-2015, 01:12 PM   #14
JusticePete
Pete,
It was a typo. About 690 front and 695 rear =/- 5mm for production tolerance.
