Old 09-05-2015, 12:44 PM   #1
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
misfire cyl. 6 & 7 only
I put the stock cam in, and had the dealer put in a new ECM and flash it with the correct vin to put the car back to a auto transmission.
Now the car has a nasty misfire, but only on cylinders 6 and 7; which is very odd.
Do I need to do a case relearn?
I would post the files, but apparently we can not attach HP tuners log files.
I'm going to pull the plug and check compression on both the cylinders, but I suspect it is fine. I actually pulled the front of the motor off a second time to double check the cam timing, it is correct.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
