Old 09-06-2015, 03:00 PM   #1
mckeddie
Drives: 2010 camaro
Another 2010 Timing Chain
My 2010 is in need of the timing chain being replaced. just at 80,000 miles, and warranty just expired. this is my first problem that I've had with the car to date. i know that this is a very common problem, and that there is an extended 10 year 120,000 mile warranty on all the other GM's with this motor. I've always done used Mobil1 at scheduled intervals with a k&N oil filter for the life of the car, and it sees 95% of its miles on the 122 mile round trip drive down the interstate for work with the cruise set at 75.
Has GM done anything to help anyone with this to date? or am i stuck doing it myself? I've already bought everything to do it, chains, tensioners, sprockets, the works. just don't know how i'll find time to actually work on it with my work schedule (14 hours a day, 6 days a week).
for the time being, the car is just sitting in the driveway rotting away, looking all depressed till i figure out what to do.
the only modifications to the car, are a long tube intake, and flowmasters, as well as suspension, so nothing that would contribute to any additional wear on the timing chains.
what are my options? and what have others done?
thanks,
greg
mckeddie is offline   Reply With Quote
Old 09-06-2015, 10:32 PM   #2
Travis102
Drives: 2010 camaro rs
i need info on this too
Travis102 is offline   Reply With Quote
Old 09-07-2015, 07:46 AM   #3
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
The dealer may do a one time good will repair for you. Some people have had luck with this after going to their servicing dealership.
TheHorse13 is offline   Reply With Quote
Old 09-07-2015, 08:37 AM   #4
myold88
myold88's Avatar
Good luck but I doubt you will get any help from GM. You say you change your oil on "scheduled intervals".
In my opinion that not nearly enough. I've done 9 changes in 6 years and 38,000 miles on my '10 SS.
Usually my computer says 60-70% remaining. Either way, good luck getting your Camaro repaired.
Old 09-07-2015, 10:20 AM   #5
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
A timing chain is a normal wear item. Unless you can prove it was defective, I would not expect any sympathy from the dealer. A chain should not be worn at 80k, hell most belts do not need service till 100k.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 09-07-2015, 02:13 PM   #6
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
thanks,
greg
Greg,
How do you know when a timing chain needs replaced? I also have a 2010 SS & am now concerned.
All Yhe Best
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 09-07-2015, 02:15 PM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Originally Posted by Orange 2010 Camaro View Post
Greg,
All Yhe Best
Orange 2010 Camaro
You should have no problem with your timing chain. This is a V6 issue not a V8 problem.
Old 09-07-2015, 08:24 PM   #8
mckeddie
Drives: 2010 camaro
I change it every 5,000. Most of the miles have come in the last 2 years driving it to and from work. I bought a new work car Friday, gotta swap a tranny in it, then the camaro is going back to weekend warrior/toy status.
Old 09-08-2015, 03:42 PM   #9
TooCool5
TooCool5's Avatar
I don't know why chains keep going, could that be why GM has switched to Dexo's oil instead of full synthetic?
