Old 09-08-2015, 01:45 AM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Coil Spring Covers/ Sound detonating material
There has been some noise coming from my rear end on the rear left side. I mainly hear it at low speeds and when i apply pressure/bounce the car almost on the top of the rear wheel i can produce the squeak/noise. Im thinking it may be the spring but before i take it to the shop im wanting to purchase a set of those spring coil covers that youve seen on some aftermarket lowering springs in hopes of it being the fix.
Nighthawk89 is offline   Reply With Quote
Old 09-09-2015, 12:09 PM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Bump.
He's looking for like what comes on the pfadt springs. To see if the sound is a quick fix, or if it's something else..
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 09-09-2015, 02:21 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
This may do it- http://ltsuspension.en.alibaba.com/p..._ID_75mm_.html
I'm not sure of the size, but I expect they can lead you in the right direction!
