Old 09-08-2015, 01:09 PM   #1
BlackMagik
Drives: 2014 Camaro Z/28
Will 335's fit?
Hi Guys,
I have a new set of street wheels and tires coming in from HRE for my Z. I am using the factory offset and sizes but will be using a 20" diameter. I am going to use the Michelin Supersports one way or the other, but they only come in the following sizes for a 20" 30 aspect tire.
305/30/20
335/30/20
The Michelin sport cups come in a 325/30/20 but I want to get away from a racing tire for my street rubber.
I know several guys on here have fitted the 325's with no issue, but has anyone scrunched a 335 on their wheels? Any fitment issues?
Clearly if there is fitment issues, I'll simply run the 305's again.
BlackMagik is offline   Reply With Quote
Old 09-08-2015, 09:58 PM   #2
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
Well I guess no one knows the answer to this so you have got to do it and then tell us all if it worked or not. I am thinking about the 20 inch wheels also and the michelin pilot tires but was not going that big.
Bigtime53 is offline   Reply With Quote
Old 09-09-2015, 12:14 AM   #3
Paul2x
Paul2x's Avatar
Drives: 15' Z/28
I've seen 335's on a Z but it was with 18' forgelines - My guess is 18x11 but don't know the specifics of the offsets
..all sorts of fast!
Paul2x is offline   Reply With Quote
Old 09-09-2015, 09:54 AM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
OP But the Z/28 comes with 19 are you going up on the rim size? if so i think you will take out the wheel well extenders, tire will be to tall.
Old 04-09-2018, 01:45 AM   #5
jerseytaylor
jerseytaylor's Avatar
Drives: 2015 Z/28. #935
Bumping this
Interested in running 335 out back albeit with the stock 19s (19x11 / 11.5)
Any insight on this? Doable?
jerseytaylor is offline   Reply With Quote
