Old 09-08-2015, 02:15 PM   #1
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
eBay Headers, will these fit? Any good?
My exhaust system is bone stock, and I would like to go with a set of headers, and was curious if these are any good? Also will they bolt straight up? And if they will cause the O2 sensors to throw any codes?
Ebay Headers 1
or these?
Ebay Headers 2
Explit Player is offline   Reply With Quote
Old 09-08-2015, 05:21 PM   #2
thebigbankhank
Drives: 03Avalanche,2012cbr1000rr,2010iomSS
been wondering this myself.. along with some ebay mufflers and tips and see what happens... under 1k into a full exhaust system, if it last 10 years them id be more than happy...
thebigbankhank is offline   Reply With Quote
Old 09-08-2015, 05:28 PM   #3
EnzoR
EnzoR's Avatar
Drives: 2012 1SS6M
On the top link; They will work, you will have to pay a shop to weld in an extra 2 bungs for the rear o2's and use the stock gasket. I had these on my old 2010 l99 with no fitment issues and they sounded great, are great quality don't let anyone tell you different. I would recommend having a way of tuning the vehicle afterwards as this is going to make the car run like crap and throw CEL'S. You have to have the rear o2 plugged in even without the cat to keep the CEL'S from poping up. The LS3 may have fitment issues with the oxygen sensors hitting the bottom of the car but this can be remedied with welding in extra bungs to relocate.
Last tip; if a shop installs these you have nothing to worry about because they are skilled at adapting when it gets to custom exhaust. If you do it your self leave extra time during the install as something may pop up such as fitment issue(oxygen sensors and connecting to oem cat back.
Best of luck and I hope you enjoy what a real Kamaro sounds like! Day and night difference if you go without the cats.
EnzoR is offline   Reply With Quote
Old 09-08-2015, 05:46 PM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
With ebay headers you have a 0-100% chance that they will fit perfect with no modifications. They aren't built to the specifications that a more expensive header like Kooks where they are supposed to fit every time guaranteed.
Check out my build thread
Old 09-08-2015, 05:52 PM   #5
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
IMHO ,just get the TSP or SP headers and save yourself any problems. Both fit and function perfectly .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-08-2015, 05:57 PM   #6
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Ive heard alot of Horror stories about ebay headers, best bet is TSP or SP on a budget. You will also need O2 Extensions and someone to tune out the rear O2's, a proper dyno tune is recommended to get the most out of any LT Header upgrade.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 09-08-2015, 05:59 PM   #7
Kings2010
Kings2010's Avatar
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins
Look for speed engineering on eBay. Same price. Also search the forum for eBay headers.
The speed engineering received a good review from a c5 member. Provably what I'll put on my car. Bolt right up with no probs.
I also contacted speed engineering directly and asked for a picture of the inside of the collector as I was concerned about the presence of a merge spike.
They do have one and the picture I received put my concerns to rest.
B.
Kings2010 is offline   Reply With Quote
Old 09-08-2015, 06:05 PM   #8
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
I've also heard good things about obx headers
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 09-08-2015, 08:40 PM   #9
Squishy
Squishy's Avatar
Drives: 2016 camaro 1SS
Stay away from the cheap ebay headers man, Nothing but trouble
2016 BLK Camaro 1SS/LT1 M6:
NPP | black front/rear bowtie | Blacked out taillights
2011 IOM Camaro 1SS/RS LS3:
Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley
Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter
Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors
Tuned by Lashway Motorsports - 501 Hp 430 ft-lb
Squishy is offline   Reply With Quote
Old 09-08-2015, 08:53 PM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
DO NOT I repeat DO NOT get 1 3/4 headers!!!!!
You want cheap headers get these at least
http://m.ebay.com/itm/2010-Camaro-Lo....c100408.m2460
62nalide is offline   Reply With Quote
Old 09-09-2015, 06:30 AM   #11
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
I would also not suggest you use the cheap bolts they send with those kits. Like others have said use OEM gaskets and pick up some good header bolts. As for fitment, they should be fine.
These companies use high end parts for the specs for theirs. They can sell them for cheap because they have no research and development costs and most of the time do not stand by the parts they make. It's a roll of the dice my friend!
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 09-09-2015, 06:39 AM   #12
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
Spend a little bit more money and get some Stainless Works headers. Several forum sponsors sell them. They fit well and they'll last longer.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 09-09-2015, 12:07 PM   #13
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
I used speed engineering. They fit perfect.
supergt99 is offline   Reply With Quote
Old 01-08-2016, 11:23 AM   #14
locktyght
locktyght's Avatar
Drives: 2023 LT2 Redline
Will the Speed-Engineering headers fit to the stock (NPP for me) cats?
Also, If I opt for the off-road connection pipes, will that require fab work?
http://www.speed-engineering.com/sho...stainless.html
2015 1LE sold
2016 2SS sold
2023 LT2 Redline
locktyght is offline   Reply With Quote
exhaust, headers, tuning
