Old 09-10-2015, 05:23 PM   #1
radical radick
Drives: 2010 Camaro 2SS/RS
Tail light problems!!!
I've got a 2010 camaro ss passenger tail lights don't work all the time. This just started a couple days ago. I'll turn them on and after a little while the right side would just turn on. Checked bulbs, grounding,plugs and noticed low voltage on the right side. If anybody has a wiring diagram please send it to me. Help
radical radick is offline   Reply With Quote
Old 09-11-2015, 08:43 AM   #2
radical radick
Any suggestions to check?
Old 09-13-2015, 01:16 AM   #3
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
When you tested the lights, did you use an alternate ground or a ground from the light harness? Also, did you use a test light or just a DMM (digital multimeter). A DMM will only show potential voltage where as a test light will induce an amp load on the circuit.
cajun1le is offline   Reply With Quote
Old 09-18-2015, 06:37 PM   #4
radical radick
I used both, I traced it down to BCM. Appears to be solid state relay problem. Thanks for your time
