Old 09-15-2015, 04:34 PM   #1
plastrd
Indecisive
Drives: 2010 Camaro SS/RS
EPDM cap for brake reservoir clutch outlet
Long ago I separated the brake and clutch reservoirs and at the time I put a cheap rubber cap on the outlet from the brake reservoir. That plug since broke down due to the brake fluid and now leaks. The inner fender paint under the reservoir is already all peeled up from the leaky reservoir cover (just found that TSB today after 100k miles of being annoyed by it!) so I'm just looking to patch up the sources now.
I found plenty of posts saying an EPDM cap is what I need for the outlet but I can't find any sizes or part numbers I could look for. The closest I found was a suggestion that NAPA has them (is this it?). Does anyone have a part number I can look up and order or at least a size to search for? Failing that, what size is the hose so I can put a stub on with a bolt jammed in the end and hose clamp it?
plastrd is offline   Reply With Quote
Old 09-15-2015, 05:56 PM   #2
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Yes, that NAPA cap is the same one I used, #6601698
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 09-16-2015, 02:10 PM   #3
plastrd
Indecisive
Thank you for the confirmation. The NAPA nearest me has terrible hours so I went looking elsewhere as well. The Dorman 02256 3/8" bypass cap (and 02253 multi-size pack) is also EPDM according to an email I just got back from Dorman tech support and safe for brake fluid contact. My local Autozone carries this brand (and is open later than 5:30) so I'm going to stop there tonight and pick some up along with a tiny hose clamp for good measure.
