Old 09-16-2015, 02:26 PM   #1
leggettjd
leggettjd's Avatar
Drives: 2012 Camaro ZL1
Why is an A6 faster than M6?
Hi, I just recently purchased a ZL1 A6 and it is my first automatic transmission in years. I keep on reading that a stock automatic is just a little faster 0 to 60 and quarter mile times than the stock manual transmission. How could this be? I know the transmissions have gotten better on the automatics over the years, but on paper, the manual transmission has more RWHP and torque than the automatic. Can someone please explain to me on why does a vehicle with less HP & Torque (A6) show faster times than the (M6)? Also, the SS Camaro is 426 HP for manual and 400 HP for automatic. Why is there not a deduction of HP on the automatic ZL1s like the SS models? Thanks for your input.
leggettjd is offline   Reply With Quote
Old 09-16-2015, 02:30 PM   #2
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Well, it depends who's driving the M6, but essentially, the computer does the shifting in an auto. same as a computer can add numbers faster than you. No skill required. Just press the go pedal and hang on. There, that should get it started.
Welcome to Camaro5 OP
Old 09-16-2015, 02:30 PM   #3
TXsilvy
Drives: camaro
an automatic transmission is faster and more consistent than 99% of people out there...and an automatic is faster in drag style racing. I'm pretty sure the manual has an advantage in road course style racing.
TXsilvy is offline   Reply With Quote
Old 09-16-2015, 02:35 PM   #4
leggettjd
leggettjd's Avatar
I agree with your statement, but the automatic is still almost 30 HP less at the wheels than the Manual. That should still give a manual vehicle an advantage even is there is some human error...
Old 09-16-2015, 02:42 PM   #5
TXsilvy
Drives: camaro
dynos are a tuning tool. the number it spits out doesn't make one car faster than the other.
Old 09-16-2015, 02:43 PM   #6
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
It is all about gearing. The stock auto has a first gear providing much more torque multiplication than what the manual transmission first gear does. To compensate for this many manual transmission owners change rear end gears to obtain similar total torque multiplication (effects through the entire drive train).
edneyens is offline   Reply With Quote
Old 09-16-2015, 02:54 PM   #7
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Wait?! What? The zl1 auto trans looses horsepower too like the ss autos?!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 09-16-2015, 03:23 PM   #8
krisprz2010camaross
Originally Posted by leggettjd View Post
Read down the Article to see HP ratings for auto and standard
http://www.leftlanenews.com/new-car-...let/camaro-ss/
I know the auto ss loose power, but I didn't know that the zl1's do as well. The article doesn't mention the zl1 horsepower thought
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 09-16-2015, 03:24 PM   #9
leggettjd
leggettjd's Avatar
That is what I am trying to figure out why loose HP on the crank with automatics on the SS, but not the ZL1. Could be GM playing with paper HP numbers......
Old 09-16-2015, 03:28 PM   #10
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
We should have enough dyno runs around here to figure it out.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 09-16-2015, 03:35 PM   #11
Mkn95u0
Mkn95u0's Avatar
Drives: 2012 IBM L99
I thought the SS had less HP because the cam isn't as aggressive in the L99 due to the AFM or whatever?
ZL1 will be on paper the same, they both use the LSA, but the L99 and LS3 are different in a few aspects...
Dyno the ZL1's and the auto will probably lose more than the manual though.
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M
11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M
10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M
10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D
Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS)
Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM
Mkn95u0 is offline   Reply With Quote
Old 09-16-2015, 03:44 PM   #12
leggettjd
leggettjd's Avatar
I believe that I found the answer to my question concerning the SS
http://www.ehow.com/info_8762452_dif...e-l99-ls3.html
Old 09-16-2015, 03:58 PM   #13
krisprz2010camaross
This is the first time I have ever heard that apparently auto zl1s loose have less power than manuals.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 09-16-2015, 04:14 PM   #14
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
The actual acceleration stock vs stock is about identical. If you roll race to you likely find they are identical. The constant acceleration of the auto makes up for the little efficiency difference.
The ET difference is almost all within the first 60' and certainly within the 330' because the auto applies the power smoother and can make boost before it even moves.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
