Drives: 2013 Camaro SS and 2016 Camaro SS Join Date: Jun 2014
Hurst Stage 1 Spring Kit for 2010-2014 Camaro SS
Part #6130000
![]() Application: Fits 2010 - 2014 Chevrolet Camaro SS Models. Features: The Hurst Stage One Spring Kit is an excellent choice for firming up the handling of your car and giving it that 'Just Right' stance. These springs will lower your vehicle approximately one inch, closing up that fender gap, lowering your center of gravity for improved handling and braking, and improving overall driving feel. Through careful design and rate tailoring, the Hurst Stage One Kit accomplishes all of the above while still being street friendly - truly a 'win-win' situation. Keep it firm, keep it low, keep it HURST. -High Performance Handling -"Just Right" Stance for the perfect muscle car look -Daily driver / Street friendly -Lower Center of Gravity (will lower the vehicle approximately 1 inch) Product Attributes: Bar Size (in): 0.545 (Front) / 0.610 (Rear) Bushings Included: No Coil End Type (1): Pigtail Coil End Type (2): Pigtail Color/Finish: Hurst Gold Powdercoat Constant or Variable Spring Rate: Constant (Front) / Variable (Rear) Max Compressed Diameter (in): 3.689 (Front) / 4.089 (Rear) Package Contents: 2 Front Springs & 2 Rear Springs Package Quantity: 4 Progressive Rate Spring: Yes Spring Position: Front & Rear Spring Rate: 134-215 LBS/IN (Front) 275-425 LBS/IN (Rear) Uncompressed Diameter (in): 6.375 (Front) / 5.560 (Rear) Uncompressed Length (in): 11.500 (Front) / 10.375 (Rear) Last edited by HurstPerformance; 06-29-2016 at 07:27 PM. |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
What are the front and rear spring rates? It appears that the fronts are actually slightly softer than stock?
#4 | |
Front: 134-215 LBS/IN Rear: 275-425 LBS/IN |
![]() Drives: 2015 2SS/RS/1LE Join Date: Jun 2015
Anyone go this route for their springs? I am curious to hear your thoughts and see pictures of your stance.
| Tags |
| chassis, hurst, springs, suspension, wheels |
