Old 09-18-2015, 11:31 AM   #1
500rwhp
Cocaine
500rwhp's Avatar
Drives: 2015 White 1SS/RS/1LE*NPP*RECAROS
custom cam
these are the specs im being told...
230 .590 range 115+2.
with headers and cam with tune. said I would be 465 plus rwhp.
not a car guy or know what this exactly means(spec wise)... but any insight would be good.
any vidoes of someone with similar setup.
kooks headers 17/8 a
custom cam 230 .590 range 115+2. with BTR parts
15 1le with npp
500rwhp is offline   Reply With Quote
Old 09-18-2015, 07:21 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Well that sounds like a better than stock cam with more duration, you must mean the numbers are more like 230/230 duration with .590/.590 exhaust and intake lift and 115+2 LSA Lobe separation angle which in conjunction with the cam center line matter a lot and this cam sounds more than enough to be a street friendly not too radical cam that should net you those numbers or even a little higher on a dyno. That means you are a lot more duration and lift along with a tighter LSA than the stock cam, and the cam runs 2 degrees advanced to make it more street friendly to add to its LSA as the stock ls3 cam had lots of LSA... the stock cam was like .550 lift and have here from this article the specs of the cam from a 2010 ls3
Duration: 204°/211°
Lift: 0.551″/0.525″
LSA: 117°
I have heard of the ls3 with even more LSA as it was installed..with +
Maybe reading about these three cams could help you understand more. Good luck, that cam sounds middle of the road for performance but easy on the valve train.
http://www.lsxtv.com/tech-stories/en...e-engine-dyno/
Old 09-19-2015, 12:08 AM   #3
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Who specd the cam? The LSA seems a bit wide to me for a N/A application.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 09-20-2015, 12:48 PM   #4
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Depending on the full cam spec it could be a good cam for drivabilty and power. Just depends on the valve events. Feel free to contact us if you need help with your cam choices.
Shawn
Lethal Racing is offline   Reply With Quote
Old 09-20-2015, 02:42 PM   #5
500rwhp
Cocaine
500rwhp's Avatar
Yeah that's what they said. It's better for drivabilityl since Mines a dd. Goes in next week. Thanks
Sent from my SM-N910T using Tapatalk
FOUNDER - NY/NJ/PA Domestic Car Club Est.2013
Custom Grind Comp Cam 114 Lobe * Brian Tooley Push Rods, Springs * Kooks 1 7/8 LT Headers * Comp Cam Trunion Bearings * NGK TR55 Spark Plugs * Rotofab CAI * Dyno Tune * GM Performance Dual Mode Exhaust * GForce 1000 HP Axels* BMR 1" Lowering Springs, Trailing Arms, Toe Rods, Upper Control Arms* Full Rear Bushing Kit * 500/441
Old 09-20-2015, 04:33 PM   #6
pir4te
Moonshiner
pir4te's Avatar
Drives: Holden SS-V L77 flex fuel
custom cam
My car is a DD too, a 2011 Holden SS-V Sportwagon 6.0 N/A.
I have 226/230 115+2 0.550" retained AFM and swapped in VVT. Also upped compression to 14:1 for ethanol incl. pistons, valves, basic race prep.
Stock stall, 2.92 gears, drives great with 480rwhp and 27.5 mpg hwy on e85, 1/4 12.4 @ 116 full two ton weight.
Sounds lumpy enough at 650rpm, massive torque for daily driving with cam parked, phase in 6° retard and revs past 6600.
[video]http://youtu.be/t4A4PY3tTts[/video]
Compression is King.
Naturally as-pirated, all-motor, all alcohol.
pir4te is offline   Reply With Quote
Old 09-20-2015, 11:45 PM   #7
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
My cam has 12 degrees of overlap and also a 112+2 and it's my daily driver. No issues. Bucks some of course but that's only really if I let it. It's pretty easy to work around it. I would recomend it to any daily driver honestly.
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
