Old 09-18-2015, 10:04 PM   #1
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
Looking for Reverse Sense +12V Under Dash...
Hi guys, I am looking for a reverse sense +12v signal under the dash somewhere, and hope someone has found a connection point to share.
I am removing my glitchy Metra w/ onstar retention kit (keeping the DDIN w/Climate parts) , and replacing it with a Scosche GM19B 44 pin connector and the Axxess ASWC-1 steering wheel interface.
So I have all the wires I need except the reverse signal for camera switching, and instead of tapping into one of the reverse light bulbs and running a wire all the way to the front, I would rather tap in under the dash.
Any help appreciated.
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 09-19-2015, 05:41 PM   #2
rray
rray's Avatar
I found it! Gray 26 pin BCM plug, pin 3, light green wire, above accelerator pedal.
I would have just bought the Metra replacement part if it was available, but they are a greedy company that does not sell replacement parts for their dash kits, and I have already bought 2 just to get a replacement for when the heater controls went on the fritz with the first kit. Saved $250 this time.
backup camera, camera trigger, reverse sense, reverse trigger
