Old 09-22-2015, 09:49 AM   #1
Z288racer
Drives: 2015 Camaro Z28
How to replace front seat
The stock z28 is a great seat, but too big for my hips when driving on the track. I want to replace it with Recaro Profi seats that fits me perfectly.
Anyone knows how to bypass the seat airbag and seat belt warning lights?
THANKS!!
Z288racer is offline   Reply With Quote
Old 09-22-2015, 04:34 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Try these first:
http://www.1010thsmotorsports.com/an...seat_pads.html
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 09-24-2015, 04:06 AM   #3
X25
X25's Avatar
Drives: '16 C7 Z51
I currently have the Recaro seats (powered; actually sits lower than manual Z/28 Recaros by about an inch), but I am having issues at the track. The belt openings are too low on the seat, so my shoulders are a bit compressed. The seat is also sitting way too high; I have the feeling of racing with an SUV seat. FYI, I am currently using the seats along with Schroth Rallye 3 ASM harness and a HANS device.
Is there any solution where I can have a harness bar at the track day, but easily remove it once I'm done? I hate the idea of effectively canceling the rear seats.
Regarding airbag, there are small simulators sold on ebay for $15 or less. You can also simply put 3K Ohm resistor on the circuit to fool it (so the error light would not light up, and the rest of the airbags would still work). You would also need to carry the OEM seat belt receptor and position sensor, if any, to the new seat. Position sensor would only need to be connected. It normally signals only if the seat is too close to the steering wheel, but your race seat set-up will probably never be too close anyway.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 09-29-2015, 10:26 AM   #4
Z288racer
Thank You!
I noted a difference between the driver seat and the passenger seat. There is a small control box under the passenger seat and none under the driver seat. Anyone knows what's it's purpose?
The passenger seat seems easy to do - the seat can be disassembled and the original track can be used with the seat belt bracket and the harnesses. Have not figured the driver side yet since the seat track on one side has a welded bracket.
Old 09-29-2015, 03:28 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
To know if there is any one in the seat and if its all the way forward (as if its in back seat passenger is coming out.
Old 12-15-2015, 07:10 AM   #6
tylerio
EXTREMZ
tylerio's Avatar
Drives: 2015 Z/28 #891, 2012 2SS 45th Anni
I am 6' tall and am cramped when wearing helmet in my son's 2012 SS. His is the stock, motorized seat. I recently purchased a 2015 Z28 and I'm hearing that the stock manual Recaro seat affords less headroom than the motorized seats of the SS.If so, I'm gonna have a problem. I've also heard that the motorized version of the Recaro sport seat sits lower than the manual version. Can folks confirm this? If true, is it easy to swap out the manual seat for the motorized one? Also, where to buy the motorized Recaro? Thanks!
tylerio is offline   Reply With Quote
Old 12-15-2015, 02:15 PM   #7
X25
X25's Avatar
Drives: '16 C7 Z51
I do own a '14 SS 1LE with no sunroof. With the stock non-Recaro seats, I had a tiny bit more than 37" of space between the bottom-lowest part of the seat and the roof. When I switched to manual Recaros, presumably same as Z/28 seats without the logo, my headroom has dropped to about 36". Since then, I switched to the powered unit ($2500 MSRP; I think I got it for $2200 or less), and the headroom was back to around 37", though I believe the stock seat still provided a small amount of more headroom.
If your son's SS does not have a sunroof and yet you don't have enough headroom, you might need to consider aftermarket setups. That will also mean you'll have to deal with sensors and airbags, but it probably beats driving your own car cramped.
Old 12-15-2015, 09:47 PM   #8
tylerio
EXTREMZ
tylerio's Avatar
Thx x25. It's weird, the Chevy website specs say that the headroom on the z28 is 37.4". Must be a mistake. Anyway, I'm off to purchase a helmet tomorrow and we'll see if I can fit in the car. The SS headroom was tight, but manageable with the helmet on. If the Zs headroom is indeed 37.4" as Chevy says, I should be ok. Otherwise, motorized Recaro here I come.
Old 12-15-2015, 09:53 PM   #9
X25
X25's Avatar
Drives: '16 C7 Z51
As I mentioned before, my car is a 1LE. I doubt that the floorplan would be different, but I'd love to be wrong. You should let us know.
My brother's Viper GTS' seats came with spacers, which let us gain another 1" once we removed; I wish it was that easy with the Camaros : )
