Old 09-23-2015, 01:01 AM   #1
Camaro_Mike
Drives: 2011 CGM SS LS3
POSSIBLE ENGINE DAMAGE DUE TO OIL PUMP FAILURE!!!!!!!!!!!!!!
So the low oil pressure display popped up on dash yesterday. I had just drove the car about 12 miles, and parked it for about an hour. As soon as I start the car back up the low oil pressure light turns on. It tells me to shut the car off so I turn it off. I then turn the car back again for a couple of seconds, message comes up again. Tried it one more time with the hood open to listen for ticking. My engine makes noise all the time so I really didn't know what to pay attention to. I did hear some ticking, but it was not loud at all and it was barley noticeable, it sounded pretty normal to me. Im pretty sure it is the oil pump, or possibly an sensor. My car is an 2011 LS3 w/42k miles, no engine mods and NO WARRANTY. It just ran out a couple of months ago.
-Is there anyway to troubleshoot to find out if the sensor is the issue WITHOUT turning the car on?
-Should I expect the dealership to replace my engine if there is damage done since oil pumps on most chevy v8's are known to fail?
-What actually is damaged when an engine breaks due to low oil pressure?
-Could I just replace the heads or block IF there is engine damage or do I have to replace the entire engine?
Camaro_Mike is offline   Reply With Quote
Old 09-23-2015, 02:50 AM   #2
Avenging Orange
Avenging Orange's Avatar
This may be a dumb question...but you didn't mention it. Have you checked the oil level?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-23-2015, 02:51 AM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Check oil level? The block has two plugs on the oil gallery on driver side, can thread an adapter in there with a mechanical oil pressure gauge and test. That will tell you what is it, pump or sensor. Believe it's m16x1.5 threads. You would still need to start the car. Only long enough to compare the gauges.
Do not expect Chevy to replace anything since your out of warranty.
Caswell239 is offline   Reply With Quote
Old 09-23-2015, 02:53 AM   #4
Camaro_Mike
I checked the oil level on the dash. It was at 68%.
Old 09-23-2015, 02:55 AM   #5
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
No, that the oil life not the oil level. You need to go pull the dipstick under the hood
Old 09-23-2015, 03:18 AM   #6
MrChrisLS3
Drives: 2018 1SS M6
Oil level won't tell much if the pump is out. I would also think that if it were low enough on oil to cause low pressure, the low oil level light would trigger as well. (I believe there's one on these cars)
MrChrisLS3 is offline   Reply With Quote
Old 09-23-2015, 10:32 AM   #7
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
The 2011 does not have an oil light.
If the pump failed, which by all accounts is most likely the problem, DO NOT run the motor. Running the motor without the pump working will make things far worse.
You have to tow the car to a reputable shop.
You have to replace the pump. Go with the Melling, not the stock garbage pump.
It will be in the area of $1,000 to fix with labor and parts.
There are a million threads about this exact problem. Search the forums and every question you have on this will be answered.
Internal motor damage cannot be determined by the Internet. A mechanic is needed.
TheHorse13 is offline   Reply With Quote
Old 09-23-2015, 04:29 PM   #8
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Talk to your dealer. Maybe being prone to failure,they'll warranty some if not all the work. It won't cost you anything to ask. I wouldn't give up until someone as high as I could go up declined it. They know there's a problem... Good luck
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-23-2015, 04:58 PM   #9
Avenging Orange
Lets just eliminated the obvious (no matter how dumb it may sound ) and for shits n giggles, have the OP check his oil level via the dip stick. Humor me.
Old 09-23-2015, 05:27 PM   #10
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
right?! Gotta start somewhere and that doesn't cost a dime...
gr8daneh is offline   Reply With Quote
Old 09-23-2015, 05:39 PM   #11
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Powertrain warranty is 5 years, 100,000 miles.
How do you have no warranty if you've done no mods? When did they release the 2011s?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 09-23-2015, 06:40 PM   #12
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Not all v8 have oil pump issues. It's only known with the LS3. I'm guessing the relief valve is stuck and you will need a new pump.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 09-23-2015, 07:51 PM   #13
derek1387
Drives: 2015 1LS Red V6
Right, am I the only other person who was thinking this?
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 09-26-2015, 06:39 AM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
+3
That 68% is oil life monitor not oil level. If you ever get low oil message you turn it off and check the oil level. You have a 5yr 100,000 mile drivetrain warranty. if you have oil you call GM road side assistance and they will pick the car up and bring it to a dealer. Do not restart the engine. Call GM or your preferred dealer and tell them you have a low oil pressure message and the oil level is full.
JCunningham is offline   Reply With Quote
