Old 09-14-2009, 04:02 PM   #1
gatorsrule
gatorsrule's Avatar
Drives: 2010 2SS/RS Silver Metallic
Strange noise coming from behind the dashboard on the passenger side
I took my Camaro in for a strange noise coming from behind the dashboard on the passenger side. Several mechanics said it was from a line that sends coolant to the engine as you accelerate. The problem was that none of them have been trained on the new Camaro and had no idea how to fix it. I called several dealerships in my area and all said the same thing. Is anyone else having the same problem?
gatorsrule is offline   Reply With Quote
Old 09-14-2009, 04:07 PM   #2
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
I should be able to tell you in about 3 weeks.
2010 2-Tone is offline   Reply With Quote
Old 09-14-2009, 04:50 PM   #3
ffrcobra_65
Coming from the passenger side, behind the glove box area...Does it sound like rice crispies when you pour milk in? If so, there is a tsb for it. Dealers just need to look it up and it tells them what parts they need and how it is done.
TSB 09-01-37-001
Old 09-14-2009, 06:05 PM   #4
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
I have the exact same problem. Thanks for posting this mayne.
a_Username is offline   Reply With Quote
Old 09-14-2009, 08:17 PM   #5
Sstac
Sstac's Avatar
Drives: 2010 2SS/RS Camaro
I dont have my car yet so I dunno about the noise... but the prob you are having with your dealership not being trainned on this car... thats my biggest worry once I get my car!!!
Does anyone know when dealerships are gonna have more trainned staff for the camaro?
Current: 2010 Camaro CGM 2SS RS Manual
Past: '99 camaro, '01 Z28, '03 vette '08 BMW 535i
1100, Preliminary order accepted 08-06-09
2000, Accepted By GM
09-1-09
3000, Order accepted by production control 09-1-09 TPW 09-21-09
3300, Order scheduled for production 09/11/09
3400, Order broadcast 09-12-09
3800, Order produced 09-22-09
4000, Available to ship 09-23-09
4200, Shipped 09-24-09
5000, Delivered to the dealer 10/12/09
* Picked up 10/12/09
Sstac is offline   Reply With Quote
Old 09-14-2009, 08:18 PM   #6
Lucky SOB
Drives: 2010 Camaro 2SS/RS
Yeah I have this noise too. It's kinda a squeaky/creaking noise. Right near the A-pillar. So now I have the TSB number (dont know what that means), but what is the problem?
Lucky SOB is offline   Reply With Quote
Old 09-14-2009, 11:23 PM   #7
ffrcobra_65
Google the tsb number I listed and the post on it here will pop up. Much faster than searching for it here since I can't remember which section it was in. I have the same noise in my car and I have an appt with dealer to fix it. I told the dealer about the tsb as they had no clue.
Old 09-15-2009, 07:09 PM   #8
rickerda
rickerda's Avatar
Drives: 2010 Camaro 2LT RS
Techinical Service Bullitins
#09-01-37-001: Gurgle Type Noise Coming from Instrument Panel (IP)/Heater Core Area (Perform Repair as Outlined) - (Jun 24, 2009)
rickerda is offline   Reply With Quote
Old 09-15-2009, 07:58 PM   #9
Frayles
Drives: 2020 Cadillac CT5 V and 87 Buick GN
My car 2SS/RS A6 was having the same problem. I took it in and they fixed it using that TSB as a reference. No more noise. All they do is install a valve in the hose leading to the heater core.
2SS, Nightfall Gray, A8, MRC, NPP, NAV, Blk Bowties
Gen 6
1100 01-22-2016
2000 03-22-2016
3000 03-25-2016 TPW 4/11
3400 04-01-2016
3800 04-08-2016 - Built
4200 04-08-2016
6000 04-20-2016
Gen 5
1100 04-22-2009
2000 05-15-2009
2500 05-19-2009
3000 05-21-2009
3400 06-10-2009
3800 06-18-2009
4150 06-18-2009
4200 06-19-2009
4800 06-29-2009
4B00 06-30-2009
5000 07-10-2009!!!
Frayles is offline   Reply With Quote
Old 09-16-2009, 06:29 PM   #10
Rick James
Drives: 2010 Camaro
my first camaro had this issue, it was a lemon my new one doesn't have it...
Rick James is offline   Reply With Quote
Old 09-16-2009, 07:30 PM   #11
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
yes i am having this problem fixed on friday
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 09-18-2009, 08:32 PM   #12
Warr3nc
Drives: 1969 Camaro
Subject: Gurgle Type Noise Coming from Instrument Panel (IP)/Heater Core Area (Perform Repair as Outlined)
Models: 2010 Chevrolet Camaro
Equipped with V8 Engine (RPOs LS3, L99)
Condition
Some customers may comment on a gurgle type noise coming from the instrument panel (IP)/heater core area.
Cause
Coolant flow within the heater core may be causing this noise.
Correction
Install a one-way flow valve, GM P/N 10188036, into the inlet heater hose using the following procedure.
This is the condition and correction for the problem being talked about. Nothing major just a customer satisfaction fix.
Warr3nc is offline   Reply With Quote
Old 09-18-2009, 08:45 PM   #13
Mac1
Drives: 2004 Malibu
Same here. Took it in and they found a hampster running on his wheel. They shot the hampster with a 9mm. Problem solved.
Mac1 is offline   Reply With Quote
Old 09-23-2009, 05:19 PM   #14
iflylow
Drives: 03 2500HD, 2SS/RS CGM, C-130H3
Took my car by today to have the dealer look up parts on bulletin 09-01-37-001. Turns out there is a recall #09207: Service Update for HVAC Reprogram, Engine Harness Position Inspection and rear spoiler fasteners (Sep 22, 2009). My service manager has called around and found out that after the HVAC reprogram there has been a few cars that suffer from further HVAC damage.
Noise will be fixed next week but he suggest waiting for a programming update to the recall rather than risk a more expensive fix to the HVAC system.
Hope this helps.
iflylow is offline   Reply With Quote
Strange noise that follows engine rpm - 2SS/RS SSCam15 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 76 11-17-2011 12:00 AM
Passenger Side Air Leak or Side Mirror? Icntdrv55 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 10-21-2009 10:22 PM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 11:42 PM
Strange noise TC Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 06-25-2009 03:47 AM
Passenger side. Jamestwilliams Cosmetics and Lighting Modification Discussions 0 08-29-2008 09:43 PM
