Old 09-28-2015, 08:10 AM   #1
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
Odd sound in my 2SS while turning
I traded from a 2LT to a 2SS. I never heard this on my V6 model, but on this car...the V8...I hear an odd noise when turning. It's almost sounds like the tires are rubbing/groaning on the road. This is only at low speed when turning...such as backing up out of the driveway or parking stall...or turning in a parking lot as I move forward at about 3-5mph.
Is this rubbing/groaning from the front end area (maybe tires) normal for the V8 models? Like I said...I never heard this in my V6 model.
thx
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 09-28-2015, 08:35 AM   #2
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
I have the same noise issue on my SS. I did some research and it seems as though the clutch plates in our rear end is the culprit. Changing the rear end fluid with Gm rear differential fluid and the additive should get rid of that noise. On my to do list here soon.
graf101 is offline   Reply With Quote
Old 09-28-2015, 08:39 AM   #3
BLK141SS
BLK141SS's Avatar
Drives: 2014 1SS M6 NPP
If you are hearing a gripping or tire scrub sound from the rear tires, say hello to the posi. Normal, go do some burn outs and have fun. If you are hearing mechanical sounds like clicking then try changing the fluid.
BLK141SS is offline   Reply With Quote
Old 09-28-2015, 08:56 AM   #4
Rangore
Rangore's Avatar
Thanks ya'll. No clicking...just a rubbing type sound. Wish there was a way to type out what it sounds like. I had no idea it would make that type of sound, so it worried me a bit.
Old 09-28-2015, 11:08 AM   #5
Pluto
Pluto's Avatar
Drives: 2013 Camaro 2SS/RS
I don't know if the TSB applies to your year model, but your description sounds a lot like what my car had. They had to replace the axle seals and fluid per a TSB and the noise went away. It would only happen backing out of parking spaces and doing slow turns through a parking lot. I took it to the dealer and drove a few donuts at 3-5 mph to enhance the sound.
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list:
Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket.
Pluto is offline   Reply With Quote
Old 09-28-2015, 12:48 PM   #6
14AGMSS
Drives: 2014 AGM 2SS/L99
I have the same issue on my car. Weird sound like tires rubbing when you turn either direction. Most noticeable slow speeds turning in parking lots. I scheduled service for this Thursday. I read about the tsb which I thought was just for earlier model years.
14AGMSS is offline   Reply With Quote
Old 09-28-2015, 02:30 PM   #7
Pluto
Pluto's Avatar
I had a full differential replacement at 3000-3500(can't remember) miles then at 14,000 miles or so I had to have the seals replaced with the upgraded fluid...apparently they'll leak if you just add the new fluid
Old 09-28-2015, 03:40 PM   #8
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
If it's consistent as to when it occurs (and you can make the car do it), take it to your dealer and have them check it out.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 09-28-2015, 03:55 PM   #9
Kreamsicle FreightTrain
Drives: 2012 2ss convt m6
Hub/wheel bearing
Hello,
I hear the same noise in my 2ss vert. It is an occasional noise, at low speeds is when I hear it. Mine is on the right side. I believe it is the hub\wheel bearing. If you hear it while turning right, then its the left side. If your turning right, then its the left side. I recently took my car in for the noise but they couldn't find it. Next time im going for a ride with the tech so I can point it out. Here is one video, but you can you tube wheels bearing and a tone of video will come up. Let me know if this helps.
Chris
Kreamsicle FreightTrain is offline   Reply With Quote
Old 09-28-2015, 04:58 PM   #10
15xracing
15xracing's Avatar
Drives: 2011 Camaro ss 6.2L L99
I have the same problem. I turn slow in a parking lot or out of a parking spot and its that groan noise.. Mine sounds like it's coming out the rear and it fades in and out.. I just bought the car.. It's q 2011 l99 ss
15xracing is offline   Reply With Quote
Old 09-28-2015, 05:17 PM   #11
Pluto
Pluto's Avatar
I'm almost 100% positive you're going to need the seals and fluid change. It's rather common and I dealt with it for a very long time.
Old 09-28-2015, 09:43 PM   #12
11CamaroCF
Drives: 2011 Camaro SS
Some what helpful, but I have small sounding slamming that goes on the right side of the quarter panel when I turn, sometimes. Was wondering if anyone else has heard a noise like that?
11CamaroCF is offline   Reply With Quote
Old 09-28-2015, 10:01 PM   #13
Les7311
Les7311's Avatar
Drives: 2017 Zl1 (M6)
Send a message via Yahoo to Les7311
Scribed
Les7311 is offline   Reply With Quote
Old 09-28-2015, 11:41 PM   #14
Rangore
Rangore's Avatar
Wow! Great info. Thanks. Do I tell the dealer there is a TSB on it or does this go under my extended warranty?
