Old 09-30-2015, 09:03 AM   #1
14ZL1M6
14ZL1M6's Avatar
Drives: 2015 ZL1 Coupe A6 & 2002 ZO6
Spark Plugs Choice
What plugs are you guys running? Is there one better than the other? I'm still running the stock plugs now, even with my mods.
Thanks
2015 ZL1 A6 Coupe Crystal Red
ATI Balancer w/9.55 (22.5%) lower pulley, FIC1000 Injectors, Stainless Works 2" headers, Stainless Works Retro Cat-Back, V-Max Ported TB, Roto-Fab w/Big Gulp, Elite 2nd Gen Catch Can, Jannetty Tuned. 581 rwhp
14ZL1M6 is offline   Reply With Quote
Old 09-30-2015, 09:59 AM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks
NGK TR7IX gap 0.042
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 09-30-2015, 03:28 PM   #3
14ZL1M6
14ZL1M6's Avatar
Originally Posted by JANNETTYRACING View Post
NGK TR7IX gap 0.042
What is the benefit over stock?
Old 09-30-2015, 03:50 PM   #4
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
None unless you have upped your boost. The higher an engines compression ratio the colder of a plug you will need. Increasing boost is the same as increasing the compression ratio.
Good read. http://www.pcmofnc.com/index.php/blo...ere-do-i-start
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-11-2015, 11:28 PM   #5
14ZL1M6
14ZL1M6's Avatar
Thanks for the article...It was a good read!!
Old 10-12-2015, 12:32 AM   #6
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
That calculation seems to be a little off... Basically says stock should be heat range 7. From what NGK shows stock is heat range 6.
I currently have one step colder plugs from NGK (range 7) and by that websites calculations says I should be using a range 8.
I guess it is a good place to start, but just like he says in the text it isn't the bible.
jayno20 is offline   Reply With Quote
Old 10-12-2015, 10:43 AM   #7
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Pretty much anyone with over stock boost is good with a 7 heat range. Gapping the plugs down to around .030 helps many cars with blow out issues including mine.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 10-13-2015, 07:53 AM   #8
14ZL1M6
14ZL1M6's Avatar
NGK TR7IX gap 0.042
Ted, Would this affect my tune by changing from the stock plugs to TR7IX?
Old 10-14-2015, 11:22 AM   #9
JANNETTYRACING
Originally Posted by DrkPhx View Post
I don't have a wild setup like you, but I gapped mine to .032 and it helped at WOT with no degradation to idle or part throttle driving.
If you having spark blow out issues on these cars something is wrong with the electrical or ignition system.
We can run gap of 0.042 at over 850 RWHP.
No sir no affect on the tune.
Ted.
Old 10-14-2015, 12:20 PM   #10
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
NGK TR7IX gap 0.042
Ted,
At what point, if any, is there a need/benefit to add upgraded electrical for the plugs, i.e. coils and wires? Any reason to upgrade to MSD or Granatelli parts?
Thanks
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 10-14-2015, 08:30 PM   #11
jayno20
Go fast, please.
jayno20's Avatar
Originally Posted by winterboy8 View Post
Ted,
Thanks
I've wondered this myself, especially about the coils.
Old 10-15-2015, 04:52 AM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
MSD coils are junk and many tuners have issues with them. Stock GM is more than adequate so leave them stock.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-15-2015, 09:12 AM   #13
Redlineviper
Drives: 2013 ZL1
I would say unless you are running crazy high boost levels and using exotic fuels the stock coils are just fine. The stock ones easily handle 18-19 pounds of boost on e85 or pump.
2013 A6 ZL1
Old 10-15-2015, 09:35 AM   #14
JANNETTYRACING
MSD coils are not junk, I have determined the problem is in the voltage supply to the coils.
Stock coils draw less than aftermarket coils.
Therefore installing aftermarket coils often overwhelms the voltage feed to the coils.
Many of the cars that have come through my shop with high power and spark blow out is easily fixed with a Wire upgrade to feed the coils now offered in a kit from MSD. http://www.summitracing.com/parts/msd-88867
To take it a step farther we install JMS Ignition voltage booster to feed the coils and we can run large gaps at high boost and make more power.
http://www.jmschip.com/sparkmax-igni...ltage-booster/
Ted,
Thanks
I upgrade the plugs in our 125 RWHP packages and above
I upgrade the wires when we add headers.
Ted.
