Old 09-14-2009, 10:12 PM   #1
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: was 2010 2LT RS 2G1FC1EV4A9103434
Rear License Plate LED Mod
Just installed LEDs for the rear License Plate lights -
NOTE - you need two (2) Bulb 194 w/5 LED Matrix White Single as there are two housings. I will not recommend where I got them as it took 3 weeks to get with no feedback & several attempts to email for status then they just showed up. These run $7.99-$8.99 each.
The white matches well to the HID Halos - observe local/State laws if you consider another color.
Installing the Interior / Trunk LEDs from Advanced Auto Concepts when the arrive - http://www.automotivelightstore.com/...ROD&ProdID=457 - Note - just saw they carry the 194 LED so that's a better choice...http://www.automotivelightstore.com/...ROD&ProdID=305... opt for the 5 LED.
Before & After Pics
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
tjd24 is offline   Reply With Quote
Old 09-15-2009, 06:11 AM   #2
skisax80
Drives: 2010 camaro ss/rs
i do like that.. was this just plug n play?
skisax80 is offline   Reply With Quote
Old 09-15-2009, 10:14 AM   #3
tjd24
tjd24's Avatar
Yes - its plug & play - better to do in the daylight with the lights OFF as the bulb you'll be removing is quite hot if the lights are on (with lights on use a paper towel or clean rag to remove the stock 194 bulb):
1) there is a clip at the left end of the housing - push to right and the housing should start to come down, you may have wiggle the clip to get the housing moving.
2) housing will pull out with the wires still attached to the socket, gently turn the socket to remove it from the housing.
3) Remove stock 194 bulb by pulling straight out. Replace with 194 LED, push in until tight. Re-connect socket with housing, turning socket until it locks in the housing
4) Re-seat housing in the bumper, clip goes on the left, until housing is flush & secure.
5) Repeat 1-4 with the other side. REMEMBER - there are two (2) bulbs/housing so you need to be sure you order two 194s from wherever you purchase.
Took 5 minutes to complete. I retained the old 194 blubs in the box where I keep the growing number of stock parts I've removed.
Old 09-15-2009, 10:20 AM   #4
The Dark Knight
Batmobile in Disguise
The Dark Knight's Avatar
Drives: 2009 Pontiac G8
Hmmm...I might try this when my custom plates come in...
The Dark Knight is offline   Reply With Quote
Old 09-21-2009, 11:53 AM   #5
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
Drives: 400HP 2LT/RS
JB Power Centre sells these LEDs for $13 plus tax. I just picked up two bulbs for the $13 and I'm headed outside to install them. I cant wait to see them tonight when its dark out!
Shaun
CRAZY BEE - IOM 2LT/RS (more)
Cosmetic Mods - 24 | Performance Mods - 14
ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED
DJ ATOMIX is offline   Reply With Quote
New! Retractable Front License Plate Frame/Holder! Hide your front license plate! RPI Designs Exterior Parts & Accessories 74 07-31-2020 07:29 AM
MOTORIZED FRONT LICENSE PLATE Matrix 5th Gen Camaro SS LS LT General Discussions 11 08-22-2009 05:10 AM
Hide away front license plate ? Travo Cosmetics and Lighting Modification Discussions 5 07-30-2009 01:27 PM
Looking for pic of front license plate bracket Top Flight Reproductions Camaro Photos | Spyshots | Video | Media Gallery 11 07-27-2009 11:04 PM
