Old 10-04-2015, 09:09 PM   #1
sdynak
Drives: 2014 ZL1
LS3 plug wires.. what would you choose?
So when I installed my headers one of the OEM spark plug wires had a broken terminal clip (found when removed) on the coil side of the wire which I am sure will never cause a problem but I would rather replace the set anyway. They are 5 years old so maybe its time anyway.
So knowing most recommend OEM and with headers should I stick with OEM? I am seeing options in 9" (red hi temp) and 9 1/2" black (what mine has)..
Has anyone tried the 9" to see if they fit? I like the color and they look the same but I'm concerned they may be a tiny bit too short?
http://www.ebay.com/itm/221849748377...%3AMEBIDX%3AIT
Here are the 9 1/2" same as OEM # on the wire and all
http://www.ebay.com/itm/321829174015...%3AMEBIDX%3AIT
Then there is a set on Amazon that says fits my car as ACDelco 9748UU Professional Spark Plug Wire Set
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
And then there is this set on Amazon and I'm not sure what the major difference is? The part # diff from the above is missing a "9"
http://www.amazon.com/ACDelco-748UU-...keywords=748UU
Or would you go aftermarket all together and forget OEM?
Not looking to spend a great deal of $ especially thinking the OEM are fine but willing to spend a little more if there are good reasons to do so..
Thanks in advance..
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 10-04-2015, 09:34 PM   #2
Unreal
Drives: 2006 Z06
OEM
Nick
Corvette Z06 -1200ish rwhp
Old 10-04-2015, 10:03 PM   #3
Jsafe17
Jsafe17's Avatar
Drives: 2010 2SS/RS 6spd LS3
Get the MSD units for a 6.0 truck.. they are longer because of the placement of the truck coils, a nice upgrade.
https://www.amazon.com/gp/aw/d/B0006...?ie=UTF8&psc=1
Jsafe17 is offline   Reply With Quote
Old 10-04-2015, 10:49 PM   #4
TX_ED_SS
TX_ED_SS's Avatar
Drives: 2010 2SS/RS Inferno Orange
When I added my LT Headers I went with Taylor Pro Race 10.4mm wires. Bought them on Amazon for $70.
U.S. Army Retired
TX_ED_SS is offline   Reply With Quote
Old 10-04-2015, 11:07 PM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
only OEM have the proper resistance for our ignition systems. Others will work but not as well.
JCunningham is offline   Reply With Quote
Old 10-05-2015, 01:40 AM   #6
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Accel ceramic wont ever worry about burnt wires
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 10-05-2015, 03:19 AM   #7
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
+3 OEM
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 10-05-2015, 04:24 PM   #8
sdynak
Drives: 2014 ZL1
Thanks for all the feedback.. anyone ever try the shorter red OEM 9" ..
Old 10-05-2015, 05:25 PM   #9
Bo White
Bo White's Avatar
Im a Taylor fan. That being said I have Autolites on mine.
Old 10-05-2015, 05:32 PM   #10
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Moroso Ultra 40's here. Been on every race car I have driven.
BFASTNOTLAST is offline   Reply With Quote
Old 10-05-2015, 06:40 PM   #11
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Taylor's 10.4 on mine . If you run OEM with headers get the wire socks or you will burn the wires.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 10-05-2015, 07:44 PM   #12
JCunningham
Drives: 2017 2SS M6
When do you burn the wires? Iv only put 10,000 miles on mine with 1 7/8" headers and there like new. No racing though.
Old 10-05-2015, 07:48 PM   #13
1BadAssSS
Drives: 2018 ZL1 A10
Taylor on mine.
1BadAssSS is offline   Reply With Quote
Old 10-05-2015, 08:07 PM   #14
sdynak
Drives: 2014 ZL1
Hmm.. close running for OEM VS Taylor.. if I'm going to spend a few $ if Taylor is the way to go then maybe I'll take a closer look at em.
Thanks again guys!
