10-05-2015, 01:10 PM | #1 |
Whipple Heat Extractor
Does anyone have pictures of the Whipple installed hood heat extractor on a 2014-2015 Camaro? I am trying to decide if I want to purchase theirs or modify the existing factory one.
10-08-2015, 02:08 PM | #2 |
Drives: 2016 1SS Join Date: Apr 2012
I put a Whipple on a 2011 SS that had a ZL1 hood with the Carbon Fiber insert (YES your read that right the Carbon Fiber insert ). I did have to put the plastic scoop a bit to make it work not the carbon though. I would say you should as long as you cut where it would be needed and measure twice to cut one, you should be good.
I opened and closed the hood so many times before I got it right. So take your time if you decide to do it. Best of luck. Just a tip, maybe use some modeling clay to see where you need to cut so that way your not guessing. Thank you, Ricardo |
08-06-2016, 08:28 PM | #3 |
Did you ever install this extractor... I am wanting to know how it compares to the OEM... I currently have a CF extractor from G5.R... Getting ready for a LSA Conversion... I am looking for options.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
