Old 10-05-2015, 10:36 PM   #1
kc ss/rs
kc ss/rs's Avatar
Drives: 2010 ss/rs
btr stage two vs btr stage three blower cam
thinking about changing my current setup over the winter months,and looking for some opinions. i have purchased a circle d 2800 single disc converter and was leaning more towards the stage two cam. im thinking with the stock unported heads the stage three might be overkill or even harm performance. running a maggie 2300 with eight psi pulley. if anyone is running one of these cams i would like to hear about driveability and performance gains.
rotofab cai
ported throttle body
sp headers with cats
loud mouth axle back no mufflers
tuned by steve williams 6l80etuning.com
bmr split springs
cam motion custom camshaft
btr 660 spring kit
maggie 2300
id850 injectors
livernois fuel pump
kc ss/rs is offline   Reply With Quote
Old 10-05-2015, 11:06 PM   #2
Coukostos
Drives: 2010 2SS LS3
Had the BTR stage 2 installed a couple months ago, and really happy with the gains, drivability has been fine.
I'm running more boost, but was at 533 @ 11 psi. Added the cam and meth, now at 640 (similar boost). Drivability is good to me. It needs more clutch starting from a stop, but no different otherwise after you get going.
2010 LS3 - SLP TVS2300, Stainless Power 1 7/8" LT's w/HF cats, CAI intake, Vmax TB, stock exhaust, Slowhawk tuned - 538hp/530tq
Coukostos is offline   Reply With Quote
Old 10-06-2015, 07:28 AM   #3
Reelgrinder
Drives: 2016 SS
stage 3 has no issues either.. if you think stage 3 is a big loppy idle cam, its not... there wasn't really a problem starting out with 3.73 gears but 3.91 are better in my opinion even though not needed.
I would say the 3 most common are BTR stage 3, GT9 lingenfelter, and texas Speed blower cam.
But, give Florida speed and power a shout they make some bad ass cars. plus you can ask matt the tuner what works good with the setup your thinking about.
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
Old 10-06-2015, 11:14 AM   #4
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I've had both, both are good cams but the 3 makes more power and is a good PD blower cam.
MODS:
Old 10-07-2015, 08:37 PM   #5
se7en
Drives: 10 Procharged SS
Ive had both and currently using the stage 3. I liked the stage 2 better, but the 3 has given me better drivability since going to E85. On 93 they both act the same.
I still have the stage 2 in my garage if you would be interested in it. My setup is similar to yours.
se7en is offline   Reply With Quote
Old 10-07-2015, 09:01 PM   #6
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
I went with the Stage 2 BTR cam. Love it is all I can say!
&fs=1"> &fs=1" type="application/x-shockwave-flash" width="855" height="505">
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 05-23-2016, 11:40 PM   #7
1sikss
Drives: 2011 camaro ss
Would a stage 3 cam need a stall on an auto
1sikss is offline   Reply With Quote
Old 05-23-2016, 11:49 PM   #8
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Matt has a custom grind cam that he offers, I run it and am happy with it, slight chop, nothing to brag about. But effective.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-24-2016, 07:46 AM   #9
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
IMHO the best thing to do would be to get one custom spec'd specifically for your vehicle and your mods, Pat G can set you up with a custom spec'd cam for your vehicle at really not much more than an off the shelf cam.
Bildo is offline   Reply With Quote
Old 05-24-2016, 08:56 AM   #10
10aSSee D
10aSSee D's Avatar
Yes
MODS:
Old 05-24-2016, 09:27 AM   #11
chozn4service
I had a Stage 2 and needed a stall.
Old 05-24-2016, 10:05 AM   #12
1sikss
Dam stage to seems kinda small to require a stall
Old 05-24-2016, 10:40 AM   #13
chozn4service
It was my understanding with the L99 to LS3 conversion the stall was needed. I did all the upgrades as well.
Old 05-25-2016, 03:13 PM   #14
1sikss
I talked to my tuner he said it would be fine with out a stall stg 2 and 3 just a bit higher rpm like 700
