Old 10-06-2015, 09:07 PM   #1
2SSblackRS
2SSblackRS's Avatar
Drives: 2015 2SS/RS Black
2014-15 Hood Heat Extractor Removal
Has anyone taken the heat extractor off? I want to paint my extractor a different color. How do I remove the push pins on the rain diverter? After I remove the nuts that hold the extractor to the hood, is there adhesive that holds the extractor to the hood? Any tips would be appreciated.
2SSblackRS is offline   Reply With Quote
Old 10-06-2015, 09:21 PM   #2
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
SS or ZL1? On the ZL1 there are 6-8 bolts. Once removed, I used a trim tool to separate from hood. No adhesive. Just pins that hold them in place that you can push out. If it's an SS. No clue but shouldn't be any adhesive
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
Old 10-06-2015, 09:25 PM   #3
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
For the pins use a screwdriver and pop the middle section out then the pin will pull out, super easy. take off the nuts holding the hex vent on and it comes right off.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
extractor, heat, heat extractor, hood
