10-07-2015, 06:09 AM | #1 |
Drives: 2010 Camaro SS 5th Gen 6spd SC Join Date: Jun 2015
adding 3.91 gear to eforce supercharger good idea?
Is this a good mod to do for better acceleration/from a dig? Is the 3.91 gear and supercharger combo not a good idea?
10' LS3 Camaro 2SS (blacked out) - Edelbrock Supercharger, ZL1 rims, 275/315 tires, XS Power LT headers, 3" exhaust, twin tips, Edelbrock CAI, ZL1 fuel pump/ADM FPCM, VMax ported TB, JRE fuel mod, TR6ix plugs, ZL1 spoiler/splitter/grille, KW V1 coilovers, BMR sway bars, strut tower brace, trailing arms, toe links, Prothane radius arm & subframe bushings, Slotted rotors, Hawk pads, SS brake lines, HURST short throw shifter, Scosche dash kit, Pioneer 7" radio, backup camera, Dyno - 520 rwhp/tq
10-07-2015, 09:31 AM | #2 |
Gears are a great way to improve performance but with your set up I would go with 3.70.
10-07-2015, 09:40 AM | #3 |
Drives: 2011 2ss blk/wht strp Join Date: Oct 2014
see what RPM and what gear you trap in at the 1/4. Then figure out what gear you need to keep your RPM up in power range.
10-07-2015, 01:29 PM | #4 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
3.73's might be a better choice. The 3.91 will promote tire spin, big time!
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
10-07-2015, 01:43 PM | #5 | |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
It's ideal to pass through the traps at the top of 4th gear in a manual transmission car. Does anyone know what mph stock redline in 4th gear with 3.91s or 3.73 would be on a ss m6?
10-07-2015, 02:05 PM | #6 | ||
The pricing for the 3.91 kit is pretty good. Any 3.73 kits for around same price? Thanks
10-07-2015, 02:44 PM | #7 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
To my knowledge their are no gm 3.70's gears. You would have to go richmond or another company which will be over 500 for just the gear and pinion while the gm 3.91's are around 380 for the pinion gear and install kit. It's a bummer but the 3.91's will retain a warranty. Honestly, it depends n your power band like everyone else is said. but, if you are looking to add power, don't care about a top speed top (250ish down to around 200) and you want to go fast get the 3.91's.
10-07-2015, 05:16 PM | #8 | |
I also feel the traction issues with 3.91s get blown out of proportion . Yes on a street tire it's going to spin down low. But you're gonna have traction issues regardless on a street tire when you start making 5-600 whp. I don't see it being such a big deal on a car that should run drag radials when it races anyways
10-07-2015, 06:12 PM | #9 | |
3.73 is going to cost more but I think it would be the right choice. |
10-07-2015, 09:24 PM | #10 |
I just fear going to something that's not from GM as far as gears go. Any downsides to going to different gear other then traction? Harder on tranny or axles?
10-08-2015, 06:35 PM | #11 |
No, there are plenty of people putting down 600-700 rwhp with stock axles and sticky tires. The tranny is upstream on the gears so it doesn't know the difference.
10-08-2015, 06:40 PM | #12 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
There is a good 3.70 gear out there, but it's pricey.
What is your goal by doing 3.91s?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
10-08-2015, 08:57 PM | #13 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
10-09-2015, 08:54 AM | #14 |
Writer
ZL1 has a different carrier the gears don't interchange.
PROJECT HEAVY CHEVY
