10-12-2015, 03:31 PM | #1 |
Rear rotors won't come off!! Help
I removed the brake caliper and the T30 screw on the rotor. For some reason the rotor will not come off. The e brake is not on. That's where I thought I was going wrong.
10-12-2015, 04:08 PM | #2 |
Drives: cars Join Date: May 2011
They can rust on, use force. A mallet works wonders.
10-12-2015, 04:09 PM | #3 |
Drives: 2016 1SS Join Date: Apr 2012
A rubber hammer and some WD40 should be able to knock it loose.
Thank you, Ricardo |
10-12-2015, 07:30 PM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
A BFH!!!!!!
10-13-2015, 07:09 PM | #5 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2011
I just did new rotors and pads myself. I'm sure a rubber mallet will work, but I used two bolts with nuts and washers through the holes where the calipers unbolt and it popped them right off.
12-17-2015, 02:49 PM | #6 |
Drives: 2010 2SS/RS Join Date: Jun 2009
I know this is a few months old now but a rubber mallet is the best solution.
I just did a rotors and pads on a '96 Silverado that was pretty rusty. I took my rubber mallet to them and and a few good hits and they were loose enough to pull off. |
01-02-2016, 08:43 PM | #7 |
This reminds me of when I worked at a ford dealership. we used a 3lb sledge to get the front rotors off of the 150s. They came off in chunks.
