Old 10-13-2015, 06:15 PM   #1
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
My experience with Rotofab coolant reservoir
I figured since there doesn't seem to be a lot of info out there on adding a reservoir without an aftermarket heat exchanger I'd put up my personal results from adding one.
Adding it into the stock system was hands down the easiest mod I've done to my car so far. A couple clamps, and a few cut hoses later it is completely installed and ready to go. You don't even have to worry about bleeding it, cause it will do it on its own once the car/pump is started.
So after installing it, I noticed right off the bat my IAT2 temperatures are lower in general, but the biggest difference is how fast they come down after a few pulls. I have an Aeroforce Interceptor and it is constantly monitoring IAT2 so I actually watched it drop from 110 to 84 in the matter of SECONDS. It was extremely nice to see this. I have popped the hood after every drive I've taken (one of which was about 2 hours) to verify no leaks or any problems and every time I put my hand on the tank it is cool to the touch, so I know this thing isn't absorbing heat out of the engine bay. So far, I am pretty impressed with the ease of installation and the seemingly big difference it has made with temperatures. Anyone who is interested I bought mine on ebay for 145.00 shipped. IMO, it is worth it just for the ease of bleeding the supercharger cooling system.
Here are a few pics after install:
jayno20 is offline   Reply With Quote
Old 10-13-2015, 07:30 PM   #2
Chrispy
11.91 ET Bone stock
Drives: 2015 Camaro ZL1
Nice write up and logging results.
Does anyone know if you can install this with the factory airbox?
Chrispy is offline   Reply With Quote
Old 10-13-2015, 07:38 PM   #3
jayno20
Go fast, please.
jayno20's Avatar
No you can't. Instructions say the reservoir can only be used with an aftermarket intake. One of the bolts that support the tank is a bolt used in the factory airbox location.
Old 10-13-2015, 09:50 PM   #4
AIminiS10
AIminiS10's Avatar
Drives: 2012 Camaro ZL1 - #1564
Did you drain the entire system down prior to replacement?
Thanks!
2012 Chevy Camaro ZL1 #1564
1969 Chevy Chevelle
2000 Honda CBR 929rr
2013 Focus ST (daily)
AIminiS10 is offline   Reply With Quote
Old 10-13-2015, 09:52 PM   #5
jayno20
Go fast, please.
jayno20's Avatar
Thanks!
No. Although, after taking off the bottom hose from the supercharger inlet, and the hose off of the intercooler pump, I'd say I lost about half a quart, so I probably should have.
If you're asking if it has to be drained before hand, the answer is no. I didn't drain it, but pulling the hoses off kind of drains the majority of it for you.
Old 10-13-2015, 11:10 PM   #6
WSSICK
Drives: 2014 Red Hot ZL1
I have wondered if the external coolant reservoir without upgrading the HEX would make any difference. Thanks for answering that question for the community. It appears it is time to get the external coolant reservoir.
2014 Red Hot Camaro ZL1
2002 Victory Red Trans Am WS6
2000 Lt Pewter Metallic Silverado Z71
1996 Metallic Gray Ford Taurus GL
WSSICK is offline   Reply With Quote
Old 10-13-2015, 11:17 PM   #7
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
What kind of coolant did you use with the reservoir , not sure if the supercharger has anything specific?
Hellfighter is offline   Reply With Quote
Old 10-13-2015, 11:28 PM   #8
jayno20
Go fast, please.
jayno20's Avatar
Indeed. With how easy it is to install there isn't really a reason not to.
Dex-Cool 50/50 mix. Same as what the radiator calls for. I might add a little more distilled water just to help a little more with heat transfer.
Old 10-14-2015, 12:38 AM   #9
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
I installed mine about two weeks ago... Got it from lingenfilter... Easy as pie... I used a 80/20 mix of distilled / dexcool with some redline water wetter... I also installed a Ron Davis Rad / Heat Ex / 160tstat at same time ... Cool like a cucumber ... Also the rotofab windshield washer resv 2.0 is super easy as well to install.
Crash76 is offline   Reply With Quote
Old 10-14-2015, 12:53 AM   #10
jayno20
Go fast, please.
jayno20's Avatar
I was thinking of water wetter but I've read some unflattering things about it gunking up the reservoir.
Old 10-14-2015, 01:10 AM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I've been thinking about the D3 reservoir.
Thx for this info.
Mods:
Old 10-14-2015, 01:21 AM   #12
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Thx for this info.
I've been thinking the same but the price is the deal breaker for me compared to the rotofab.
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 10-14-2015, 06:10 AM   #13
Crash76
Team 913
Can't use the d3 if you get a bigger radiator not enough room I was told... At least with the Davis...
As far as the wetter mucking things up... I have used this it the past with no issues
Old 10-14-2015, 08:20 AM   #14
CamaroI
Drives: 2010 IOM Camaro
I might have one for sale if anyone interested and it's hydro dipped carbon fiber. Brand new with install supplies. I even have the hose they recommend from Nappa. I just haven't gotten around to installing.
CamaroI is offline   Reply With Quote
