Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 10-14-2015, 02:28 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Thumbs up Pfadt suspension is BACK @ Phastek Performance
You saw that right ladies and gentleman!!
Pfadt suspension is making its way back for your Camaro at Phastek Performance!!
Got any plans on getting your Camaro on the track?? Be sure to get your car track ready with some suspension components.
And as always FREE SHIPPING!!
Lowering Springs:
Lowering the center of gravity on the Camaro will improve your appearance and handling.
1"-1.25" Drop Springs - http://www.phastekperformance.com/Dr...410402001v.htm
Sway Bars:
Get rid of that body roll with a set of Sway Bars. With the 3-way adjustable front and rear sway bars you can improve both the daily compute and still attack the track on the weekend!!
2012-2015 Camaro SS/1LE/ZL1 - http://www.phastekperformance.com/20...arts-s/715.htm
Solid Rear Subframe Mounts:
Improve traction and launch control by replacing the stock rubber bushing with these Solid Rear Subframe Mounts. These mounts eliminate rear subframe movement allowing for a smoother, more controlled launch and a reduction in vibration.
Orange - http://www.phastekperformance.com/So...0-402001-n.htm
Black - http://www.phastekperformance.com/So...0-402001-b.htm
Or if you want to dominate you class and are willing to go all out, be sure to check out the Adjustable Coilover System and other suspension components:
Street/Track Coilovers - http://www.phastekperformance.com/St...430402001n.htm
Drag Racing Coilovers - http://www.phastekperformance.com/Dr...430402002n.htm
Rear Tie Rods offer a 99% reduction in deflection which will increase traction, reduce wheel hop and improve handling.
http://www.phastekperformance.com/aF...0-402003-a.htm
Rear Trailing Arms offer a 32% reduction in deflection which will increase traction, reduce wheel hop and improve handling.
http://www.phastekperformance.com/aF...0-402002-a.htm
Sales@Phastek is offline   Reply With Quote
pfadt, pfadt suspension, phastek, phastek performance, suspension
