Old 10-16-2015, 11:00 AM   #1
Bobster
Drives: Zl1
2015 ZL1 faint whining noise on manual at idle
Maybe someone can verify this for me.When my Zl1 is idling in neutral I hear a faint whining noise.When clutch is pushed in it goes silent.I know this is a heavier clutch so was wondering if this it's normal.Normally bad signs are if you push the clutch in and hear noises not when it's released.Its done it from day one ,mileage is 1,400 miles anyone have he same noise it's very faint.
Thx
Bobster is offline   Reply With Quote
Old 10-16-2015, 02:10 PM   #2
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
It could be the throwout bearing. You will know shortly if it is.
I experienced the following up until about 5000 miles. I notice more gear noise in my transmission after a 15 minute drive. I changed the rear end fluid at 5000 miles with GM limited slip gear oil, it was dirty. Full of break in particles. I also changed the trans fluid with Amsoil and the engine. I took it on a little road trip and all is fine now. Sam
NW Sam is offline   Reply With Quote
Old 10-17-2015, 09:04 AM   #3
Bobster
Drives: Zl1
It is very faint but you can hear it.i was thinking if it was the throw out bearing it would make the noise when clutch was pushed in?
Old 11-19-2015, 10:11 AM   #4
Mario Maldonado
Mario Maldonado's Avatar
Drives: Camaro ss 1le
Did it get worse ? I have the same faint noise when the weather is cold it goes away after i warm it up i have an ss
Mario Maldonado is offline   Reply With Quote
Old 11-30-2015, 01:13 AM   #5
NMZL1
Drives: 2015 ZL1
Just picked up my new 2015 ZL1 ... bought in MN .. drove it home to NM this past weekend working my way around the big messy winter storm. Exact same noise as you describe and I've now got 1500 miles on it. Thinking I may get it in for at least first oil change and chat w/service guys
NMZL1 is offline   Reply With Quote
Old 11-30-2015, 08:57 AM   #6
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
I am going to jack this thread but would you start another thread and tell us how you liked the Z driving that far and your experiences about the trip. What kind of fuel mileage, do you have nav and how did that work, etc. thanks
Bigtime53 is offline   Reply With Quote
Old 11-30-2015, 11:16 AM   #7
Mario Maldonado
Can you take video of it ? I hope the noise am hearing is familiar too is a faint one ill post a video up it goes away after a drive
This video was taking cold weather cold start
http://youtu.be/Itk93cOvO8g
Old 11-30-2015, 11:22 AM   #8
Mario Maldonado
After a drive it sounds just normal and am pretty sure is not the tob
http://youtu.be/c13I0vb15Sc
Old 11-30-2015, 11:23 AM   #9
Mario Maldonado
Old 11-30-2015, 05:14 PM   #10
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
The factory Clutch is a dual disc system, GM went to GREAT lengths to make it quiet but it does have some noise. Likely nothing, turn up your Radio.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 11-30-2015, 06:50 PM   #11
Mario Maldonado
So do you have it too ? Is a normal famialiar sound ? Until warm up ?
Old 11-30-2015, 07:31 PM   #12
Sakudog
Sakudog's Avatar
My car used to have that faint noise at idle, clutch out, gear shift in neutral, A/C on, radio off, NPP closed... yes, now my car has a Spec ST dual disc clutch and it is WAY WAY WAY louder. :(
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 11-30-2015, 09:38 PM   #13
Mario Maldonado
Yes mine just does that lil faint whine when cold by cold i mean overnight and then start but goes away after a drive and ur right these cars are loud smh
