![]() Drives: 1LT RS Join Date: Apr 2015
Hey guys, I have a '15 1LT and as I was parked today I turned on my halos and was noticing that the one on the driver's side was flickering. It's not major flickering but you can tell if you look at it long enough. Any one ever heard of this? If so, any solutions?
Thanks. |
![]() ![]() Drives: 2014 ZL1 Join Date: Aug 2015
You can get into it and check voltages to the unit but you should be in warranty so this should be covered. Most likely a bad halo but you will need to check voltage to it and confirm.
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS |
![]() Drives: 2015 Camaro 1SS/1LE Join Date: May 2015
My SS was doing the same thing a few days ago. The dealer replaced the culprit light for free under warranty.
FYI - they will replace the entire headlamp, not just the bulb/light.
Doug
USAF Vet 1999-2007 2015 Camaro 1SS/1LE LS3 - Black (Current) 2015 Camaro 2SS/RS LS3 - Summit White (Traded) 2016 Harley-Davidson Road Glide Special - Cosmic Blue Pearl |
Are the halo's on the '14-15's CCFL? They are crazy bright compared to the previous years...
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
No, they have multiple LEDs in the halo whereas the 10-13 have only one LED at the bottom of the halo. This is why the 14-15s are brighter, but you can also see the LEDs if you look hard.
#6 | |
I'll take it in next week, see what they can do about it. Thanks!! Sent from my iPhone using Tapatalk |
| Tags |
| camaro, flickering, halo |
