Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 10-19-2015, 01:32 AM   #1
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
BMR Suspension MTCA030 Chromoly Rear Lower Control Arms
Used BMR Suspension MTCA030 Chromoly Rear Lower Control Arms. These are the earlier version, with spherical rod ends instead of the later revised delrin bushings. They still perform just as good as the newer revision. The good part is that these are adjustable, the newer version with the bushing is not adjustable. These are NOT compatible with factory length shocks or coilovers, you must use a shorter shock, such as the Strange Engineering S5003. BMR sells them or you can buy them direct from Strange. These LCA's are part of the DRP007 Drag Race Suspension Package that BMR sells, and is part of the puzzle to doing a 15" wheel conversion on your car. The newer version sells for $350/pr. at BMR. I will sell these for $250/pr. All required hardware included. These are designed for use with the XSB004 rear drag anti-roll bar. Will not work with FE4 sway bars. I can text pictures as well
Kyle2k is offline   Reply With Quote
Old 10-19-2015, 08:45 PM   #2
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Bump
Old 10-20-2015, 06:52 PM   #3
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Sold
