Old 10-19-2015, 10:00 AM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
Springs for LS9 cam.
Want some advice on springs for my ls9 cam. Would like to use BTR stuff. I have been using stock springs for a while and would like to upgrade the springs over the winter. Can someone list the specific spring kit I should use. Should I do push rods also? Also would it be worth adding 1.8 rockers also. Also what's a good spring compressor. Any and all opinions welcome. I'm at 13 psi of boost with meth currently. Just want to make things more robust.
ToddB is offline   Reply With Quote
Old 10-19-2015, 10:22 AM   #2
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
Pac 1518's with good pushrods.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 10-19-2015, 12:50 PM   #3
ToddB
Unreal please throw in your knowledge.
Old 10-19-2015, 01:05 PM   #4
Unreal
Drives: 2006 Z06
Call BTR They are the experts in this. Stock rockers are great. I wouldn't touch the 1.8s. He will probably recommend their .650 platinum springs.
Nick
Corvette Z06 -1200ish rwhp
Old 10-19-2015, 02:05 PM   #5
ToddB
Thanks
Old 10-20-2015, 12:30 AM   #6
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
BTR springs
I use BTR springs that are rated for up to 660 lift. I have used them on my daily driver that occasionally hits 7700 RPM in roll racing events.AWESOME springs. Have about 12K miles on them now, NO ISSUES .
__________________________________________
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 10-20-2015, 07:37 AM   #7
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Are you experiencing valve float or something that makes you want to change them? Honestly if you're not having any problems take that money and put it toward something else. Don't get me wrong adding better springs wouldn't hurt but I wouldn't unless it is at a "must change" point.
Trob85 is offline   Reply With Quote
Old 10-20-2015, 11:42 AM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
Hit me up Todd, I carry BTR stuff.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-20-2015, 12:47 PM   #9
ToddB
No I don't think I am getting valve float. I just run the car hard at times at 13 psi of boost and want the safety of dual springs. I try to make things as foolproof as possible. Thanks for the advice.
Old 10-20-2015, 12:49 PM   #10
ToddB
Ted.
Will do. Just researching now as car is away for the winter.
Old 10-20-2015, 12:50 PM   #11
ToddB
How about hardened rods and trunnion upgrade. Any advise accepted. Thanks.
Old 10-20-2015, 03:00 PM   #12
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Heard the trunion upgrage has more failures than stock parts. I put btr 3/8" pushrods in mine.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 10-20-2015, 03:37 PM   #13
Unreal
Drives: 2006 Z06
Nothing wrong with stock trunions. Pushrods aren't a bad idea.
Honestly if your current setup has no issue, I wouldn't mess with it. Part of the reason to run a ls9 cam is to not do valve springs or other upgrades.
Nick
Old 10-20-2015, 09:18 PM   #14
old motorhead
Drives: Maggie blown LS3 vette
What Unreal said...Unless you're running really high boost levels or really high rpm levels...the stockers really aren't that bad...seriously
old motorhead is offline   Reply With Quote
