![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT Join Date: Mar 2012
Stunned by the cost... just wow.
My passenger air bag recently started malfunctioning. Did a lot of online research (most of it here on C5), and was pretty sure that it was a malfunctioning PPS (passenger Presence sensor). Many have reported a repair cost of $700... even as high as $800.
I took it to Crest Chevrolet in San Bernardino, CA. The estimate for the estimate (yep: They estimated $104 to look at the car to estimate what the repair cost would be) was bad enough... and I braced myself for an $800 stunner. Instead, it came to $1400. Now, for $104, you don't even get a written breakdown... you get a gum- popping receptionist who gives a verbal estimate only, when she tells ya, "It'll be $1400 if you want it fixed." That's all. You then pay your $104 for the service, and you go home to curl up in the fetal position and cry. What. The. Hell. This seems to be a common problem in these cars... but it's not a recall item. GM won't help you out... if you don't have the money, and a Mack truck crosses the double- yellow, your passenger is going to face- plant without a pillow. And $1400 is a ridiculous, obscene, crazy number for something that is clearly a manufacturer defect, since I have certainly done nothing to the air bag system to have caused its untimely failure. Not pleased today. Can't even drive the car, because in addition to the red lights on the dash, the warnings on the DIC, and the flashing on/ off indicator, there's an audible chime that alerts you, about once per minute, that there's a problem with the air bags. You can't ignore it... that sound will make you utterly insane. So, I can either pony up $1400 for a manufacturer defect... or I can park this f'n car. Great selection of choices. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Time to find another shop.
AIR BAGS:FRONTAL Date Reported SEPTEMBER 01, 2010 NHTSA Reference #10036025 TSB Reference #PI-0241 Description: CHEVROLET: SIR/AIRBAG INDICATOR/LIGHT ON IN THE INSTRUMENT PANEL CLUSTER (IPC); DTCS B0074 AND B0081 SET. DO NOT REPLACE THE PASSENGER PRESENCE SYSTEM (PPS) MODULE OR SENSING AND DIAGNOSTIC MODULE (SDM) FOR THIS CONCERN. *PE Want to learn how to fix NHTSA #10036025? AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE Date Reported OCTOBER 01, 2012 NHTSA Reference #10047441 TSB Reference #SB-12-09-41-001 Description: BUICK/CHEVROLET: INFORMATION BEING PROVIDED REGARDING COUNTERFEIT VEHICLE AIRBAG MODULES. MODELS 2011-2012 CAMARO, VOLT, CRUZE. 2010-2011 LACROSSE. 2006-2010 AVEO. *PE UPDATED 12/4/12. *PE Want to learn how to fix NHTSA #10047441? Date Reported SEPTEMBER 01, 2010 NHTSA Reference #10036025 TSB Reference #PI-0241 Description: CHEVROLET: SIR/AIRBAG INDICATOR/LIGHT ON IN THE INSTRUMENT PANEL CLUSTER (IPC); DTCS B0074 AND B0081 SET. DO NOT REPLACE THE PASSENGER PRESENCE SYSTEM (PPS) MODULE OR SENSING AND DIAGNOSTIC MODULE (SDM) FOR THIS CONCERN. *PE Want to learn how to fix NHTSA #10036025? AIR BAGS:SIDE/WINDOW Date Reported OCTOBER 01, 2011 NHTSA Reference #10042304 TSB Reference #PIC-5538-A Description: CHEVROLET: CERTAIN VEHICLE EXHIBITING SYMPTOM(S) OF AN INTERMITTENT SIR INDICATOR LAMP ON OR MESSAGE DISPLAYED. *PE Want to learn how to fix NHTSA #10042304? SEAT BELTS Date Reported JANUARY 01, 2012 NHTSA Reference #10038294 TSB Reference #09-09-40-001A Description: GM: THERE ARE SEAT BELT PROBLEMS: DIFFICULTY LATCHING AND UNLATCHING BUCKLE. BUCKLE RELEASE BUTTON IS STICKING. SEAT BELT WARNING LIGHT ILLUMINATED. LIKELY CAUSED BY STICKY BEVERAGES THAT ARE SPILLED INTO THE BUCKLE ASSEMBLY. *RM UPDATED 4/ Want to learn how to fix NHTSA #10038294? SEAT BELTS:FRONT:WEBBING Date Reported OCTOBER 01, 2011 NHTSA Reference #10037184 TSB Reference #05-09-40-002E Description: GM: SERVICE BULLETIN EXPLAINING WHEN THE SAFETY BELTS ARE SUPPOSED TO LOCK. *RM UPDATED 12/6/11. *PE Want to learn how to fix NHTSA #10037184? SEAT BELTS:FRONT:RETRACTOR Date Reported OCTOBER 01, 2011 NHTSA Reference #10037184 TSB Reference #05-09-40-002E Description: GM: SERVICE BULLETIN EXPLAINING WHEN THE SAFETY BELTS ARE SUPPOSED TO LOCK. *RM UPDATED 12/6/11. *PE Want to learn how to fix NHTSA #10037184? SEAT BELTS:FRONT:WARNING LIGHT/DEVICES Date Reported JANUARY 01, 2012 NHTSA Reference #10038294 TSB Reference #09-09-40-001A Description: GM: THERE ARE SEAT BELT PROBLEMS: DIFFICULTY LATCHING AND UNLATCHING BUCKLE. BUCKLE RELEASE BUTTON IS STICKING. SEAT BELT WARNING LIGHT ILLUMINATED. LIKELY CAUSED BY STICKY BEVERAGES THAT ARE SPILLED INTO THE BUCKLE ASSEMBLY. *RM UPDATED 4/ Want to learn how to fix NHTSA #10038294? STRUCTURE:FRAME AND MEMBERS Date Reported APRIL 01, 2012 NHTSA Reference #10037570 TSB Reference #PIT-3749D Description: GM: ON SOME TRUCK MODELS THERE IS SOME FRAME CORROSION. *RM UPDATED ON 5/2/2012. *KB Want to learn how to fix NHTSA #10037570? STRUCTURE:BODY OORDate Reported NOVEMBER 01, 2013 NHTSA Reference #10054243 TSB Reference #PI-0018-B Description: GENERAL MOTORS: THE WINDOWS, FRONT AND REAR, WOULD BIND, POOR FIT, MISALIGNMENT, MAKES RATTLE OR SQUEAKING NOISES, MOVES SLOWLY AND IS INOPERATIVE. MODEL 2008-2014 VEHICLES AND TRUCKS. *PE Want to learn how to fix NHTSA #10054243? LATCHES/LOCKS/LINKAGES Date Reported APRIL 01, 2013 NHTSA Reference #10037315 TSB Reference #PI-0291 Description: GM: THE DRIVER OR PASSENGER SEAT BACK LATCH MAY BE DIFFICULT TO OPERATE DUE TO IMPROPER LUBRICATION. *RM UPDATED ON 06/25/2013. *KB Want to learn how to fix NHTSA #10037315? Date Reported MARCH 01, 2012 NHTSA Reference #10043943 TSB Reference #PIT-4893B Description: GM: DOOR LOCK ACTUATORS INOPERATIVE - PASSIVE ENTRY AND/OR BUTTON PRESS. *KB Want to learn how to fix NHTSA #10043943? LATCHES/LOCKS/LINKAGES OORS:LATCHDate Reported JUNE 01, 2013 NHTSA Reference #10038344 TSB Reference #PI-0011A Description: GM: THE FRONT OR REAR DOOR MAY NOT OPEN FROM THE INSIDE OR OUTSIDE HANDLE, THE DOOR WILL NOT UNLOCK WITH ANY METHOD. THE PROBABLY CAUSE AN INCORRECT INSTALLATION OF A HANDLE COMPONENT. *RM UPDATED ON 7/26/2013. ALL 2014 AND PRIOR GM PASS Want to learn how to fix NHTSA #10038344? Date Reported OCTOBER 01, 2012 NHTSA Reference #10032453 TSB Reference #PIT-4931 Description: GMC/CHEVROLET/CADILLAC/BUICK: A DOOR MAY NOT OPEN, INTERMITTENTLY, W/THE OUTSIDE HANDLE AND/OR THE INSIDE HANDLE. MAY BE CAUSED IF THE LINKAGE ON THE DOOR LATCH IS NOT ALLOWED TO FULLY RETURN TO ITS RELAXED POSITION. *PE UPDATED O Want to learn how to fix NHTSA #10032453? TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS Date Reported JANUARY 01, 2011 NHTSA Reference #10037932 TSB Reference #PIE-0119A Description: GM: TIRE PRESSURE MONITOR MALFUNCTION LIGHT IS ON. *RM Want to learn how to fix NHTSA #10037932? ELECTRONIC STABILITY CONTROL Date Reported DECEMBER 01, 2011 NHTSA Reference #10043012 TSB Reference #PIC-5551-A Description: CHEVROLET: SOME MODEL YEAR VEHICLES ARE EXPERIENCING A DROP/SPIKE IN SPEED ON ANY WHEEL SPEED SENSOR AFTER NOISE, RATCHET, GRIND, OR ABS PUMP MOTOR, WAS HEARD, FROM FRONT OF VEHICLE. *PE Want to learn how to fix NHTSA #10043012? INTERIOR LIGHTING Date Reported AUGUST 01, 2013 NHTSA Reference #10052822 TSB Reference #09-08-42-005-D Description: GM: SOME VEHICLES WITH A LIGHT PIPED DOOR TRIM THE ACCENT LIGHTING ON THE INSTRUMENT PANEL LOSES ITS INTENSITY OR DOES NOT ILLUMINATE THE ENTIRE PANEL. THIS APPLIES SOME GM VEHICLES WITH A LIGHT PIPED DOOR TRIM. *JS Want to learn how to fix NHTSA #10052822? EQUIPMENT:ELECTRICAL:ANTI-THEFT DEVICES Date Reported OCTOBER 01, 2013 NHTSA Reference #10053904 TSB Reference #PIC-5862 Description: GM: SOME VEHICLES MAY EXPERIENCE A CONDITION IN WHICH THE BRAKE LIGHTS REMAIN WHEN THE VEHICLE IS OFF AND PARKED. THE BATTERY MAY ALSO GO DEAD. MAKE/MODELS ALSO INCLUDED: BUICK ENCORE/LACROSSE/REGAL MODEL YEAR 2014, CADILLAC SRX/XTS MODEL Want to learn how to fix NHTSA #10053904? EQUIPMENT:AIR CONDITIONER Date Reported MAY 01, 2011 NHTSA Reference #10038763 TSB Reference #PB-11160A Description: GM SERVICE CAMPAIGN: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. 2011 CAMARO. AIR CONDITIONING COMPRESSOR MAY NOT TURN ON OR OFF. THIS IS CAUSED BY THE BODY CONTROL MODULE. *RM Want to learn how to fix NHTSA #10038763? Date Reported AUGUST 01, 2010 NHTSA Reference #10036004 TSB Reference #PI-0203 Description: CHEVROLET: WATER/MOISTURE DRIPPING FROM HVAC MODULE AT PASSENGER FEET AREA DURING LEFT HAND TURNS. WHEN USING AIR CONDITIONING ON HOT/HIGH HUMIDITY DAY AND VEHICLE IS MAKING LEFT TURN, MOISTURE DRIP OUT OF THE HVAC MODULE ONTO PASSENGER F Want to learn how to fix NHTSA #10036004? EQUIPMENT ADAPTIVE Date Reported APRIL 01, 2012 NHTSA Reference #10044219 TSB Reference #PB-12052 Description: CHEVROLET: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. ON SOME VEHICLES, HEADLINER CORNER SUPPORT BRACKET MAY TEAR OR CONTACT CONVERTIBLE TOP WHEN IN DOWN POSITION AND HAVE WIND NOISE AT REAR OR FRONT QUARTER GLASS. *PE UPDA Want to learn how to fix NHTSA #10044219? UNKNOWN OR OTHER Date Reported FEBRUARY 01, 2011 NHTSA Reference #10038295 TSB Reference #10-00-89-017C Description: GM: INFORMATION ON FIXING MULTIPLE SITUATIONS RIGHT THE FIRST TIME. *RM Want to learn how to fix NHTSA #10038295? Date Reported DECEMBER 01, 2010 NHTSA Reference #10037890 TSB Reference #PI-0327 Description: GM: THE CENTER CONSOLE AUXILLARY GUAGES MAY NOT WORK BECAUSE OF A POOR WIRE CONNECTION. 2010-2011 CAMARO. *RM Want to learn how to fix NHTSA #10037890? ENGINE (PWS) Date Reported AUGUST 01, 2014 NHTSA Reference #10056361 TSB Reference #PIP-5216 Description: BUICK/CADILLAC/CHEVROLET/SATURN/PONTIAC/ GMC: VEHICLE EXPERIENCE LOWER END SQUEAK OR SQUEAL, KNOCKING NOISE OR SEIZED ENGINE POSSIBLY THE MAIN BEARING OR ROD HAD FAILED. *PE Want to learn how to fix NHTSA #10056361? Date Reported APRIL 01, 2014 NHTSA Reference #10055422 TSB Reference #PIP-3423-K Description: GM: SOME DTC CODES MAY BE SET, P0016, P0017, P0018, P0019, P0008, OR P0009. 3.6 LY7 WITH CAM ACTUATOR DTC.THE RELUCTOR FOR THE CRANKSHAFT SENSOR PRESSED ON THE CRANKSHAFT MAY HAVE MOVED. ALSO INCLUDED BUICK ALLURE MODEL YEAR 2005. *JS Want to learn how to fix NHTSA #10055422? Date Reported APRIL 01, 2014 NHTSA Reference #10052863 TSB Reference #12-06-01-009-D Description: GM: SOME VEHICLES REQUIRE REPLACEMENTS FOR HIGH FEATURE V6 TIMING CHAIN KITS AND GUIDE REPLACEMENTS. ALSO INCLUDED CHEVROLET CAPTIVA. MODEL YEARS 2007-2013. *JS UPDATED 7/18/14. *PE Want to learn how to fix NHTSA #10052863? Date Reported APRIL 01, 2014 NHTSA Reference #10055840 TSB Reference #PIP-5168-C Description: GMC/CHEVROLET: SOME VEHICLES/TRUCKS MAY EXPERIENCE A NO CRANKING OR STARTING, CAUSED BY POSSIBLE EXCESSIVE LEAKAGE FROM CYLINDER PAST EXHAUST OR INTAKE VALVE, LOW STATIC COMPRESSION, SENSOR IS DISCONNECTED, OR WHILE CRANKING, VALVE TRAIN F Want to learn how to fix NHTSA #10055840? Complaints Recalls Investigations TSBs http://www.chevroletproblems.com/tsbs/Camaro/2011/ Just do a search for air and it is about halfway down the page.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
Master of Nothings
I would contact Chevrolet/GM directly and explain that this should be covered under a warranty. No critical parts like that should be failing so soon unless you did something to the vehicle to cause that. $1400 is def a lot of money for a sensor but maybe you can have another shop check it out? The sad part is that they probably just hooked it up to the computer to have it read out what the problem is
2010 Chevrolet Camaro 2LT/RS |
![]() ![]() ![]() Drives: 2011 Dodge Charger Join Date: Apr 2009
I assume they just hooked up a scantron or something similar to the OBDII port to determine the issue. I hate shops that charge $$ for this. You can buy your own scanner for a few hundred $$, and autozone lets you use one for free.
I would go get your own scanner to get the code and then ask around at diff shops. Dealers are notoriously expensive when it comes to repairs. I never take my vehicles to dealers after they're out of warranty.
2011 Dodge Charger
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
I remember there was a re-flash for this. For your $104 they should have looked up recalls / service bulletins.
#6 |
I appreciate the advice/ comments, my friends. I will indeed be taking it to another shop... might cost me another $100 or so, but if a second GM dealer also tells me the same thing, then I'll be more inclined to believe them. At the dealership (Rotolo) I plan to go to for my second opinion, customers can actually speak with the techs, so I can discuss TSBs/ recalls/ re- flash options. At Crest Chevrolet (where I went yesterday), I was only able to speak with the gum- popping receptionist, and I strongly suspect that the techs (who I could see out in the bays playing fiddle- fluck with each other) were probably way too busy to look up TSBs, and just figured, "Well, it don't work, by dang, so let's just replace everything!" That's my guess, anyhow.
So, I will get a second opinion, and I'll keep you posted. (BTW, the OBD scanner--- which I have and use often--- does not read these errors. It's designed for CEL codes that are triggered, but nothing shows for the air bag errors. And, for today's fun trivia, in CA, AutoZone is no longer allowed to let customers use the store's OBD units, because CA mechanics sued to prevent it, saying that too many people were fixing their own damn cars, thanks to AutoZone letting people diagnose their own problems. So, here, if you want an OBD code to be read, you either have to pay, or own the reader yourself.) |
#7 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I just fought this same issue on a 2004 GMC Sierra.
Dealer read the code as a communication error with the passenger presence sensor and wanted to change over $900 to fix it. I found the sensor itself through one of the online GM part stores for a $130 less than the dealer was going to charge me. Three months after replacing the passenger presence sensor, the service air bag light came back on. I knew it couldn't be the sensor since there had been less than 10 occasions that someone had even sat in the passenger seat. I started searching the interweb and discovered a TSB from 2004 that indicated an issue with the wiring harness under the passenger seat. Took the TSB and truck back to the dealer and sure enough the wiring harness was completely cut right at the connector. The dealer soudered on a new connector and rerouted the harness per the TSB. Three months later the service air bag message returned. This time it was another wire that was cut. Needless to say I traded the truck shortly thereafter for a 2015 Silverado. I owned that Sierra for over 11 years without a single problem. The whole service air bag and passenger presence issue just started in the last 6 months of ownership. As it turns out, my 13 yr old dog could no longer jump from the ground to the back seat of the pick up. I started having to move the passenger seat all the way forward so she could jump to the floor first and then jump to the back seat. My moving the passenger seat forward and back crimped the wiring harness and eventually cut through all the wires. Took about 3 month for this to occur each time. So the moral of the story is make sure you haven't cut any wires under the seat before you replace the passenger presence system. Looking back I'm 99.999% positive I didn't need to replace the original sensor. Just so you know, my dealer says that when one air bag is inoperable, all the air bags are inoperable. Don't know how true this is but I sure wouldn't want to find out in an accident.
#8 |
Consistently inconsistent
Drives: 2015 2LT Summit White Join Date: May 2015
If one airbag is inop, it doesn't necessarily make them all inop- they say that to cover their ass. Once there is an issue with the system, all bets are off how it will react in an accident and nobody will take the liability of telling you either way.
Check connections under the seat- I'll bet you can find the problem. As for the guy saying "just call GM and tell them is should be under warranty" that's just not how it works. The warranty is clearly stated. That doesn't mean you can't call and ask for them to participate in the repair or show some good will in that sense, but the terms of the warranty are specific.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface. |
#9 |
Drives: Camaro Join Date: Jan 2015
Why do you keep going to GM dealerships? Are there any reputable independent mechanics in your area? They can all diagnose and fix the issue for half the price
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
google chevrolet customer assistance.
#11 |
I've tried a couple of independent shops, local places that I trust... halfway through any attempt to describe the issue, I'm told, "Whoa, buddy... that's a dealership issue... nobody's going to touch that!" From what I understand, no matter what the issue here, the SDM will need to be flashed/ re- flashed/ programmed/ whatever, and only the dealership holds the magic key to perform that maneuver. I avoid dealerships like the plague, I really do... I do 90% of my own work, 8% of it goes to local shops. Only that 2% of crap that nobody else seems to be able to do goes to the dealership.
I've been under the seat (well, I removed it), looking for wire- based failures. Even had an automotive electrician go through it, hoping to find a loose, disconnected, or frayed wire... no such luck. All wires and harnesses seem to be 100%. Damnit. |
#12 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Go to a Cadilac dealer, they have access to the same info. They fixed mine under warranty 2 years ago. I think they may have better customer service as well
#13 |
Panama-Gulf War Vet
Drives: '11 SW 1LT/RS 6M Join Date: Apr 2011
Did you check your fuses? You need to look at the owner's manual.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
I'm not sure I want mine to work and have a chance of spraying shrapnel at me or my love ones. It seems like everyday a new model is part of that.
